But for a 400, could anyone help me?
I need a picture like this, But of a 400
I need a picture like this:
My FZR6 Rebuild
My FZR6 Rebuild
Re: I need a picture like this, But of a 400
BMiller should be able to help you out with that request
I can get you one in the next day or two, but not right now...
Are you looking for something specific? I've got a pretty good memory of what mine looks like under there if you've got a question about where something goes.
- FasterThanUr
- 100+ Posts
I happen to have mine off.It's far from stock tho.It did look more like your pic once apon a time.The thing thats mostly different is the location of the coils
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I want to get rid of the radiator filler neck so I can use the fzr400 air box I have to fit under the yzf600 tank, but I f read your sig right I need a 05 r6 radiator to do that, thanks for the picFasterThanUr wrote:I happen to have mine off.It's far from stock tho.It did look more like your pic once apon a time.The thing thats mostly different is the location of the coils
My FZR6 Rebuild
My FZR6 Rebuild
I got a r6 radiator on its way
One more bracket I can cut off.
My FZR6 Rebuild
My FZR6 Rebuild
- FasterThanUr
- 100+ Posts
Yeah I have the 05 rad.I just used two long bolts"See Red Arrows in pic"And bolted that to the top of the rad.
And I did just have the bottom bailing wired to the header,but when I did the r6 headders I put in a bracket
It works great.I was able to use both fans without them rubbing,but it was vary close
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
- shredex
- 2000+ Posts
Genesis wrote:I need a picture like this:
whats that thing coming out of the frame where the rust is with the holes??
this does not exist on my bike
I was curious about that too, my 400 doesn't have it either.shredex wrote:whats that thing coming out of the frame where the rust is with the holes??
That is because I have a 600 it holds the front of the air boxashtong63 wrote:I was curious about that too, my 400 doesn't have it either.shredex wrote:whats that thing coming out of the frame where the rust is with the holes??
My FZR6 Rebuild
My FZR6 Rebuild
Don't know if you still need it but here's what my '90 400 looks like.
I have since run the wiring harness up through the frame spar so I could put on the airbox. Boy did that suck...
Obviously I'm an idiot, I do have that but it's bolted on and is a different color.Ashton wrote:I was curious about that too, my 400 doesn't have it either.
Thanks, I am trying to figure why the 400 air box sits further forward than the 600 air box. that 400 engine must sit further back in the frame.
My FZR6 Rebuild
My FZR6 Rebuild
Did you just plumb you FZR inlet to the lower right corner outlet? and vice-versa? the FZR outlet to the upper left r6 inlet?FasterThanUr wrote:I happen to have mine off.It's far from stock tho.It did look more like your pic once apon a time.The thing thats mostly different is the location of the coils
My FZR6 Rebuild
My FZR6 Rebuild
- mxryder21
- Level 1.5
dude, is it possible to mount the r6 rad how you have it on a 600 frame? NICE JOBFasterThanUr wrote:Yeah I have the 05 rad.I just used two long bolts"See Red Arrows in pic"And bolted that to the top of the rad.
1993 YZFZR61 ***UNDER CONSRUCTION***
I am working on a bracket with modking right now I will keep you posted.mxryder21 wrote:dude, is it possible to mount the r6 rad how you have it on a 600 frame? NICE JOB
My FZR6 Rebuild
My FZR6 Rebuild
