quick turn throttle
quadboy22p
quick turn throttle
does any body know if there is a throttle sleeve you can swap in that will make the throttle a quick turn. on my buddies zx7 ninja we put a zx10 sleeve in it and it made it 1/4 turn throttle. thanks
- the_finch
- Level 8.5
Re: quick turn throttle
I think Shredex swapped an R1 throttle assembly (the whole assembly) onto his 600 for a 1/4 turn throttle. You might be able to do the same thing to your 1000.
1997 FZR600RJ
