YZF600 fuel pump on a FZR
match417
Level 8.0
Level 8.0
Post by match417 »
does it draw too many amps for the relay? Has someone plugged one into their system and it's worked fine? I don't want to fry another relay..lol, i've already lost two, from trying stuff like this, thought i would ask first this time. I just want to plug the relay into my harness, the R1 fuel pump ran fine on the stock carbs, but that was running through it's own separate relay, i want to put the YZF6 pump with the YZF6 carbs since i have them both now and avoid all of the extra wires by plugging it into my harness.
cad600
Re: YZF600 fuel pump on a FZR
Post by cad600 »
A YZF600 fuel pump should work just fine. I think the only difference between them is the direction of the inlet and outlet tubes.
Hell, Modking has a fuel pump from a Fuel Injected R6 on his bike. You should be able to make it work.
R3TARD
Level 4.5
Level 4.5
Post by R3TARD »
just FYI dude you can crack those burnt relays apart and fix them in 5 minutes with a solder iron
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
match417
Level 8.0
Level 8.0
Post by match417 »
really? i never opened one..i always resolder burnt out stuff, sweet! i'm doing it! i have my old fried relays too. both fried by running the R1 fuel pump through my system.
and modking has a fuel injected pump on his bike?? i'd like to see how he set that one up, the fuel pressure is a lot higher on the FI bikes
