Brakes rubbing?
Brakes rubbing?
I've noticed that my brakes hiss when I move my bike around the garage. I'm assuming that a little rubbing between the pads and rotors is normal, but they also seem to be slightly warped/bent in one spot. I notice that the hiss gets more pronounced at this spot and I can feel a slight amount of extra resistance. It doesn't seem to affect the driveability of the bike, it goes as fast as I want. Is this something I should be concerned about? Should I look at replacing one or both of the rotors?
Re: Brakes rubbing?
generally do rotors in a pair.....
if you dont notice when riding then dont worry about it
I get some brake drag around the garage no biggie
SOLD
SOLD
Re: Brakes rubbing?
If it's nothing to be concerned about, I'll happily save myself $300 and live with it.
Re: Brakes rubbing?
Mine seems to do that as well but Im leaving it alone unless I can come up with a couple free rotors. Them things are high dollar!
Re: Brakes rubbing?
perfectly normal, if its a squeek, like metal to metal, then its time to worry
