Any ideas?
NOW ITS SLIPPING
NOW ITS SLIPPING
aside from the rattle i have when the bike is running, the clutch is now slipping when its cold and the biting point is now right at the end of travel of the clutch lever. I have adjusted the clutch at the engine end and readjusted the free play at the lever but its still the same.
Any ideas?
Any ideas?
Re: NOW ITS SLIPPING
Let it warm up.
...ROGO...
1993 Yamaha Fzr 600-RIP
Stock
1990 Yamaha Fzr 600-Current
Mods
Updated R6 Voltage Regulator/Rectifier
Flush mount Front Signals
R6 Headers Modded By That-Kid
Leo Vince R6 Highmount Exhaust
520 Chain and Sprocket Conversion
YZF600R Front End Swap
Front and Rear YZF600R Brake Swap
YZF600R Swingarm Swap
92 Fzr Single Upper
8000k HID Headlight Kit
95 YZF600R Gauge Cluster
02 R6 Tail, Fender Eliminator and Intergrated Tailight
YZF600R Gas Tank
Rear Tire Hugger
http://www.myspace.com/rogo420
facebook---Andrew Rogo Rogowski
Fzr Forum===WnyRogo93Fzr
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
good one, but surely the biting point should be around half way instead of at the end??WNY ROGO wrote:Let it warm up.
The slightest touch on the lever causes it to slip even when warm
Oil? What kind did you use? What about adjusting clutch.
He said hes adjusted both points. The only thing I could think of is maybe the clutch is going. Did you look at it and see if it is beat or wore or broken?
...ROGO...
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
95FZR600 wrote:Well then, time for a new bike then.
Payne - it may be time to pull the clutch pack, inspect the disks, springs, basket and hub.
I agree in that it's time to inspect the clutch. If you have to replace the clutch it's neither hard nor expensive to do it yourself.
I looked at the plates when it was in bits and they were within the spec listed in the manual, and steel plates didn't look warn either.
I have been told that if the clutch plates have been replaced before with some cheap ones, that could cause it, but i never remember it being this bad before it was stripped.
The oil i'm using is what is listed by yamaha, don't know what oil was in it before.
I've ordered a clutch cable just incase it is stretched and causing these problems, but if that don't work then i guess i'll have to strip the clutch down and recheck the plates, basket etc.
Thanks for all the help
Did you check the basket and hub for notches? While de-clutched, the plates vibrate and pound grooves into the basket fingers and hub splines; the plates can hang up in these grooves and can't be properly squeezed together by the pressure plate.
