Hey fellas!!
yamaboy
Level 1.5
Level 1.5
Hey fellas!!
Post by yamaboy »
I'm trying to find a cheaper thermostat/o-ring , and was wondering what coolant it's the best/where to find?, based on your experience..I called the dealership and they want $40 for the t-stat.. That's ridiculous..
Thanks for any feedback .
1995 ,FZR 600,Factory Pro 1.1Ti Jet Kit, Yoshi slipon,K&N filter,elevation 4200 ft above sea level.
Carb settings: Main Jet 110, Starter Jet 52.5,Needle @ 3rd position,23m Floats,about 3 turns IM Screws.
80's-90's,Rap..music.?? http://www.last.fm/listen/user/unsmenar/personal
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
i took my thermostat in to napa and they matched it up with one. You should do the same.. I refused to pay $40 for mine, I got mine for $7, drilled a hole through it for the bypass because it didn't have one on the new thermo..it was fine. It's napa brand 115 (part number 115, not temperature, it's a regular 180 degree thermo). And you might be able to match up an o-ring too, i can't remember if I had them match up one for me, or if I reused mine.
95FZR600
Re: Hey fellas!!
Post by 95FZR600 »
So did you drill out the bypass hole bigger?
cad600
Re: Hey fellas!!
Post by cad600 »
I bought a new thermostat from the dealer before I realized I could get one from eBay. The NAPA part looks like a good solution.
As for the coolant, I run distilled water with one bottle of water wetter. Dropped my temperature about 10F degrees. Here is a link to a thread discussing some of the different products available for this. viewtopic.php?f=2&t=96&start=0 One question to ask yourself though is - Are you going to try to do any track days? - Most tracks will only let you run straight water, water with water wetter, or water with some other mixture that is similar to water wetter (but I can't remember the name).
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
95FZR600 wrote:So did you drill out the bypass hole bigger?
yeah, accidentally..lol, it just takes a little bit longer for the thermostat to open up. if it ever starts to give me problems on long cruises then i'll go buy another $7 thermo and drill it out smaller
oh, and how do you guys mix in the distilled water? half and half like when mixing it for cars? I also heard someone talk about putting a little laundry detergent in the coolant mix too. How much is put in? Or is it just put in if you don't have distilled water and you use regular water?
NHFZR600
Level 2.5
Level 2.5
Re: Hey fellas!!
Post by NHFZR600 »
Match is that an EVO head on your avatar?
Leftover 07 Silver Ninja ZX6-R
**SOLD**
1990 FZR 600 Satin Black / Metallic Black Frame / Metallic Copper wheels
- Mods -V&H PIPE & HEADERS - 1999 R6 TAIL - 2001 UNDERTAIL - INTEGRATED LED TAIL LIGHTS - 2000 YZF TANK - 1995 YZF FRONT SUSPENSION AND GUAGES - MICHELIN PILOT POWER 120/60 ZR 17 - 1995 YZF REAR SWING ARM AND WHEEL W/HUGGER - METZLER ROADTEC Z6 170/60 ZR 17 - Xentec 8000K HID HEADLIGHTS - WHITE LED LIGHTING KIT
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
NHFZR600 wrote:Match is that an EVO head on your avatar?
Toyota Gen III 3sgte head, not evo. I have a Gen III in my celica. Evo heads are red and don't have the big towers on the front by the cams.
NHFZR600
Level 2.5
Level 2.5
Re: Hey fellas!!
Post by NHFZR600 »
ahh gotcha... dont have any need for or know anyone who would be interested in buying a 2000 SiR B16A2 with 20k mi on a new block and rebuilt head do you?
**SOLD**
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
that was the day that I got back with the HKS cams in it, and new valvetrain about a year and a half ago, i had just opened the box, dropped in the R6 coil overs, sard injectors, and put on the cam sprockets..then took the pic :D
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
NHFZR600 wrote:ahh gotcha... dont have any need for or know anyone who would be interested in buying a 2000 SiR B16A2 with 20k mi on a new block and rebuilt head do you?
B16A2? I know B16 is honda, what is the A2 designate? sorry, i'm not a honda guy and just know a little bit about the codes. and i don't hang around honda guys, no particular reason..lol.
NHFZR600
Level 2.5
Level 2.5
Re: Hey fellas!!
Post by NHFZR600 »
the A2 is the newer Gen B16. the B16A is the JDM version of the engine. yea it is a honda its the 160hp engine that powered the 99-00 Civic Si & SiR. pulled it outta mine after collision. the engine is in great mechanical condition just could use to be cleaned up a bit cosmetically...
**SOLD**
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
JDM is the way to go..the whole reason why i used the Gen III instead of the Gen II, and also because it's newer and was stock in the GT-Four version of my car in japan. I still need an AWD tranny, they are hard to come by, when i changed the clutch in the evo last week, i made a cardboard template of the tranny bolt pattern to see how well it will line up with my block. haven't matched it up yet..can't wait though
yamaboy
Level 1.5
Level 1.5
Re: Hey fellas!!
Post by yamaboy »
cad600 wrote:I bought a new thermostat from the dealer before I realized I could get one from eBay. The NAPA part looks like a good solution.
Most likely I won't to any track day. Just cruizing, going to work, and some twisties. So for example , where would I find 50% Glycol/50% water (ie. Premixed)? Walmart or Napa? From what I remember from the factory manual normal coolant ,for example Prestone 50/50 cannot be used because it hurts the internals. It needs to have Glycol in it , right??
Thanks for the info guys..U Rock!! RRBike
yamaboy
Level 1.5
Level 1.5
Re: Hey fellas!!
Post by yamaboy »
match417 wrote:i took my thermostat in to napa and they matched it up with one. You should do the same.. I refused to pay $40 for mine, I got mine for $7, drilled a hole through it for the bypass because it didn't have one on the new thermo..it was fine. It's napa brand 115 (part number 115, not temperature, it's a regular 180 degree thermo). And you might be able to match up an o-ring too, i can't remember if I had them match up one for me, or if I reused mine.
OH ,nice man .. I'll go to Napa for sure. Any issues? Yeah , $40 is overpriced :yikes: .
match417
Level 8.0
Level 8.0
Re: Hey fellas!!
Post by match417 »
yamaboy wrote: OH ,nice man .. I'll go to Napa for sure. Any issues? Yeah , $40 is overpriced :yikes: .
just bring in your old one when you go to napa to double check my part number, make sure the temp is the same, height, width. And i haven't had any issues with it so far, but I haven't sat in traffic with it yet, or been on any long cruises around the island.
