reusing spark plug?
- shredex
- 2000+ Posts
reusing spark plug?
some of you may know that I have killed a few spark plug because of my leaking gasket....
I was wondering if I let the plug sit long enough to dry out, it they would be reusable??
Re: reusing spark plug?
I always light them with the lighter to dry them off and then put them under the wire wheel. Make sure you set the gap and try them.
Yeah what Mark suggested is good so try that first. But if you have 5 or 10 bucks head to Advance or pepboys and get autolite 4303's. I'm actually running champions in my 1000 and they are fine. It's not really a requirement to run the NGKs. Plus they cost too much.
- shredex
- 2000+ Posts
I just have like 3-4 plugs that all fawled in the same two months in the same head...sweekster wrote:Yeah what Mark suggested is good so try that first. But if you have 5 or 10 bucks head to Advance or pepboys and get autolite 4303's. I'm actually running champions in my 1000 and they are fine. It's not really a requirement to run the NGKs. Plus they cost too much.
so they were just flooded..
if I can re-use them, then that would be great.
my second head plug went out yesterday
the other 3 have never gone out...I have never changed them since I bought it...(sept)
Gasket? I would have taken that money spent on a tank or other r1 stuff and got my motor straight first. Nothing sucks worse than having sweet looking bike sitting there with a bad motor
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Shredex,shredex wrote:some of you may know that I have killed a few spark plug because of my leaking gasket....
Put them in the oven (NOT microwave) at a LOW temp and dry them out.
Yo will then need to clean them of soot with a steel or brass brush. Use them before relying on them as a back up set.
- shredex
- 2000+ Posts
yamaha_george wrote:
Shredex,
whats a low temp???
like 100 F?
- slayermd
- Level 5.0
shredex wrote:yamaha_george wrote:
Shredex,
whats a low temp???
like 100 F?
Whatever temperature you bake your cookies at.
No idea as to what actual degrees, I just put the Madams oven (NOT while she was around !!) on to the lowest it would go, leave for about 1/2 hour and pull them out . They are definitely too hot to handle for quite a while :-}shredex wrote:yamaha_george wrote:
Shredex,
whats a low temp???
like 100 F?
The lowest I can go on a digital oven is 200 degrees.
Hi,95FZR600 wrote:The lowest I can go on a digital oven is 200 degrees.
considering what they see and shunt in the way of heat on our bikes that should be ok.
In your place i would try ONE and see the result. As I said use a steel but preferably a brass wire brush (used for cleaning suede shoes etc) to clean the plug AFTER being cooked as the soot crap will be brittle not gungy.
Please take photo's of a before afterwards so we can add this to the WIKI as a FACT rather than as I have it as a guestimate.
Just think you can be a famous author :-}
- DEMORAL1ZE
- 100+ Posts
- Location: SOUTHEAST MISSOURI--------LAND OF THE FREE, HOME OF THE BRAVE
call me crazy but just go get some more...........what, they are like a whole dollar
YOU CAN TWIST PERCEPTION BUT REALITY WON'T BUDGE
D,DEMORAL1ZE wrote:call me crazy but just go get some more...........what, they are like a whole dollar
you had better tell us where you get your plugs from.here in the UK they are 6UKP (8.75 USD) EACH for the medium quality ones and about 8+ UKP for the precious metal versions.
I did mention that (in a previous post) they could be used as emergency back-up set after gapping & testing..
- shredex
- 2000+ Posts
they cost $5 for the NGK CR9E/CR8E.
so why spend $20 when I can reuse the old ones and use that $20 for something I could use like gas and parts to finish the USD fork swap and so on.
I dont make enough to just go out and keep getting all this new stuff.
i work 4-10 hours a week at $8/hr
George, I will try it with one plug and see how it turns out.
Iv got a wire automotive brush that I can use to scrap it
THNX Shredexshredex wrote:DEMORAL1ZE wrote:call me crazy but just go get some more...........what, they are like a whole dollar
