Factorypro flywheel
BDK flywheel
home made flywheel
Whilst removing weight is always good, there is also a problem with too little weight to even out the power "pulses" of the engine firing, this is particularly noticeable in corners at the race track when you slam the throttle closed and turn and then throw the bike upright & nailing the throttle.dru86 wrote:The stock flywheel weighs 1.6kg which is weight I would like to loose for trackdays and since the factorypro total loss rotor is $180 I've decided to make my own. I'm basically going to machine the rotor down to the red circle then machine in the pickup lugs. I'm facing abit of a dilemma atm as I'm not sure whether to mill in the lobes at the same stop/start degrees, which is what can be seen marked on the rotor (this will shorten the length of the lobes, but not the exposure time to the pickup) or to have them start at the same point however be the same length as the original lobes so would have a later stop point. From the pictures I've found of total loss rotors It's hard to tell. I'm inclined to think that I'll leave them at the same stop start degrees.
home made flywheel
Dru,dru86 wrote:The stock flywheel weighs 1.6kg which is weight I would like to loose for trackdays and since the factorypro total loss rotor is $180 I've decided to make my own. I'm basically going to machine the rotor down to the red circle then machine in the pickup lugs. I'm facing abit of a dilemma atm as I'm not sure whether to mill in the lobes at the same stop/start degrees, which is what can be seen marked on the rotor (this will shorten the length of the lobes, but not the exposure time to the pickup) or to have them start at the same point however be the same length as the original lobes so would have a later stop point. From the pictures I've found of total loss rotors It's hard to tell. I'm inclined to think that I'll leave them at the same stop start degrees.
you still need the pick-ups for the ignition.shredex wrote:there is a battery you can get for bikes which allows you to completly remove your flywheel/stator...
it also is about the size of a wallet and weighs alot less than a stock battery and produces more juice also...
but its f**king expensive...
