600 and 400 subframe
Are the 600 and 400 sub frames the same design? If not, how different are they?
Re: 600 and 400 subframe
The 400 bolts to the it's frame, while the 600s sub-frame is welded to the frame. They are; however, both steel - the subframes that is.
- abs929cbrrr
- 1000+ Posts
nothing is the same about them at all.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
So they are built completely differently? I ask because I saw a guy put a new r1 tail onto a 400 sub so I was wondering if it would be the same for a 600 sub.
- abs929cbrrr
- 1000+ Posts
yeah you can swap tails on any bike but the subframes are not the same if you were thinking of using 600 parts on a stock 400.
Hi Travis,Travis wrote:So they are built completely differently? I ask because I saw a guy put a new r1 tail onto a 400 sub so I was wondering if it would be the same for a 600 sub.
You can with work fit any tail to a FZR, I have seen Aero-techs, R1, R6, Ducati, GSXR & even a Honda Blackbird tail all fitted BUT it takes a little bit of bracket making & welding in some instances.
HTH
