mounting dyna coils
- 100+ Posts
Re: mounting dyna coils
You wanna come out to Cali and pretty up my bike?
What do you do if you have the YZF 600 tank installed?
- shredex
- 2000+ Posts
you say "NOPE!"95FZR600 wrote:What do you do if you have the YZF 600 tank installed?
does the yzf tank have an airbox space? if it does, then do the same thing...
- megaloxana
- 2000+ Posts
modking indeed
'92 FZR 600
Did you weld tabs for the plate to screw into?
Do YOU Scopper?
- 100+ Posts
thatkid wrote:Did you weld tabs for the plate to screw into?
I just drilled and tapped 6 small holes into the top of the frame for M5 bolts , this design keeps more hot air below the carbs where it belongs and gives you a place to mount HV coils , HID ballast , ect,ect.
- slayermd
- Level 5.0
Ill be getting the Dyna coils soon, Ill find a way to mount them and post it up. It wont be as pretty as Modkings tho.95FZR600 wrote:What do you do if you have the YZF 600 tank installed?
