will a fuel pump off newer bikes work on the fzr? like an r6 fuel pump? or cbr?
That way we dont have to deal with that clicking sound when we turn the ignition on.
fuel pump alternitives?
- slayermd
- Level 5.0
Re: fuel pump alternitives?
If they are for a FI bike then no. I think a R6 will work because they run the same PSI (i think). The clicking isnt that bad anyway.
- shredex
- 2000+ Posts
its just when im hanging out with other guys and im the first to start my bike and our conversion is interupted by the fast clicking and everyone around me is like "What the F*ck is that?"slayermd wrote: The clicking isnt that bad anyway.
I should just tell them that its my turbo charging....
- slayermd
- Level 5.0
They understand that fuel pumps can make that noise. That just means its working too
A 5-9psi self regulating automotive fuel pump will work (as long as it's similar in physical size to the stock one). This is something you should be a bit proud of though. You obviously know A LOT more about bikes than the guys you ride with. Honestly if it's not broken there's no need to fix it.
Just tell 'em that it's the power band resetting.........
"ehhhh..that's just the flux capacitor charging.....'
On my FZR400, I mounted a Vacuum pump off of an SV650.
Works great.
XIII
Works great.
XIII
CCS #13
~There is not an end, in my challenge.
It is the life I chose to continue running
Time for some new friends.shredex wrote:its just when im hanging out with other guys and im the first to start my bike and our conversion is interupted by the fast clicking and everyone around me is like "What the F*ck is that?"slayermd wrote: The clicking isnt that bad anyway.
