Ok here is a short list of the stuff on this bike.
This is a 1990 FZR400 frame
Complete 1998 YZF600r motor conversion with ONLY 5800 miles on it. Includes radiator, full wiring handle bar switches and all.
Yoshimura racing header, R6 mid pipe, over over racing end can made out of FULL titanium. Not just the outside sleeve. It is SUPER light.
FZR400rr swing arm conversion
Fox racing shock with remote reservoir it is the new fox shock with the ride height adjustment.
TZ250 rear wheel with 520 conversion
1998 GSXR 750 front end with a carbon fiber front fender from a Aprilia Mille
6 pot brake calipers with steel braided brake lines
ducati 748 front wheel and speedo drive - the ducati speedo is the same ratio as the YZF speedo so it works like stock.
I have installed in the YZF600r fuel level indicator so there is a light not a reserve switch
Full FZR400rr body work including tail assembly that is welded professionally so you can take a passenger safely
FZR400rr projector beam headlights
carbonfiber tank cap
GSXR600 rear brake caliper
Almost new Pirelli Diablo tires front and back
Custom airbox
new battery
I am hoping to get 4000 but I am negotiable I have WAY more money into this bike. I suggest shipping it through forward air. They are cheap and very reliable and fast
Write if you have any questions.
Noah
