Alternative replacement brake rotors
ozzyfzr
Post by ozzyfzr »
theres plenty of discs about that will fit the FZR - Range
Yamaha shares this rotors: 320mm
· FZR 250 87-
· TDR 250 88-92
· TZR 250 87-92
· SRX 400 (3VN1/3VN2/3VN5) 90-96
· SRX 600 (3SX) 90-91
· SZR 660 96-97
· FZR 750 Genesis 87
· YZF 750 R/SP 93-97
· FZR 1000 Genesis 87-88
· FZR 1000 EX-UP 89-95
· XJR 1200 95-98
· XJR 1300 (5EA1) 98
To make the list complete:
000 Specs:
- outer diameter: 320 mm
- inner diameter: 64 mm
- thickness: 5 mm
- setback: 10,5 mm
APRILIA:
- CAPONORD RAID from 2003
- ETV MANA from 2002
- RSV MILLE from 1998 till 2000
- RSV MILLE R 2000
- RSV MILLE SP 2000
- SL 1000 FALCO 2000
DUCATI:
- 620ie MONSTER from 2001
- 620 SS from 2003
- 748 DESMOQUATTRO from 1994 till 1997
- 748 E/S & R from 1998 till 2002
- 749 also S from 2003
- 750 SS from 1991 till 1998
- 800 SS from 2003
- 800 SPORT from 2003
- 851 from 1988 till 1991
- MH 900 E 2000
- 900 M MOSTRO from 1993 till 2000
- 900 SS from 1991 till 1998
- MOSTRO S4 from 2001 till 2002
- 916 all models from 1994 till 1998
- 996 from 1999 till 2001
- 1000 MOSTRO from 2003
YAMAHA:
- YZF 750 R from 1993 till 1995
- FZ 1000 R from 1987 till 1989
- FZR 1000 EXUP from 1989 till 1995
- XJR 1200 from 1994 till 1998
Hope it helps someone struggling to find replacements!!!!!!!
BOLT PATTERNS ARE THE SAME
LIST IS FOR FRONT ROTORS ON THE FZR RANGE OF 1000'S AND 750'S WITH 320MM FRONTS, NOT REARS.
Ozzyfzr
It looks fast! is it
Target30
Level 7.5
Level 7.5
Re: Alternative replacement brake rotors
Post by Target30 »
thats a great list. are the bolt patterns the same on all of these also?
I did that.
docrider
100+ Posts
100+ Posts
Post by docrider »
Target30 wrote:thats a great list. are the bolt patterns the same on all of these also?
Agreed that was my question too
airtech R1 solo tail, russell racer front brake lines, dynojet stage 3 jets, K & N pod filters, V & H SS2R exhaust system, 89 gsxr 750 rear wheel
haunter
Post by haunter »
I know lots of the Duc ones bolt up, the snowflakes, on the 1ks and 750s
ozzyfzr wrote:theres plenty of discs about that will fit the FZR - Range
Ozzyfzr
Nice one Mate, well done WIKI material for sure !!! :notworthy:
SHOGUNTX, kindly check that my WIKI version of this is Syntacticly correct Thanks
95FZR600
Post by 95FZR600 »
How about a sticky on this one? And maybe lock the thread? What do you think rage?
cad600
Post by cad600 »
Most of these are for the rear brake only. I've got a spread sheet that also has front brake compatability that I'll try to get posted up tonight. The WIKI has the FZR brake model number from 3 different manufactures that I used to cross reference to find other makes that use the same disk. The front brakes are only 298mm as well not 320mm.
haunter
Post by haunter »
95FZR600 wrote:How about a sticky on this one? And maybe lock the thread? What do you think rage?
this is what the wiki is for :deal:
:cheers:
ozzyfzr
Post by ozzyfzr »
To answer your questions I have edited the original post at the bottom, to save scrolling up, the list is "320mm FRONT" rotor replacements with the same stud/bolt pattern and offset!
Regards
Ozzyfzr
cad600
Post by cad600 »
That makes more sence now. All of those are for a FZR 750/1000. Most of us thought you were talking about the 600 since that is what most of us have.
Good info to have.
ozzyfzr wrote:To answer your questions I have edited the original post at the bottom, to save scrolling up, the list is "320mm FRONT" rotor replacements with the same stud/bolt pattern and offset!
Regards
Ozzyfzr
I have updated the wiki to show this new info
Y_G
Return to “WIKI - Discussion, Submissions, Corrections...”
