Where does the big ground cable go?
Just overhauled my gearbox and got the bike together but I can't remember where the biggest black ground cable attaches (the one from the negative battery terminal)? Can't seem to find it in my clymer manual either, anybody got a pic or directions?
- slayermd
- Level 5.0
Re: Where does the big ground cable go?
I think that goes on the engine, somewhere near the back.
That helps alotslayermd wrote:I think that goes on the engine, somewhere near the back.
No really. Anybody got a pic?
- slayermd
- Level 5.0
I can give you a pic in a few hours. its just a ground wire, so anywhere on the engine or frame will do.
But the engine is aluminum right? So it dosent conduct?slayermd wrote:I can give you a pic in a few hours. its just a ground wire, so anywhere on the engine or frame will do.
Thanks alot!
Hi,fzraudun wrote:Thanks alot!
Logically it must go to the block else the spark plugs would not work faultlessly. If it went to the frame you may have poor connectivity thro inter-metal corrosion or paint being an insulant.
