ignition timing wrong or...
metalizzer
Post by metalizzer »
Hi m8
I have an fzx 4AM with a FZR 1000 2RG 1988 engine
if i put the coils on what is supposed to be the correct firing order (1243) cylinders on the right side 3&4 dont work and no noise
if i put the coils on order (1324) all cylinders work but it makes a noise similar to valves
thnx
metalizzer
Re: ignition timing wrong or...
Hi monologue!
UPDATE:
I finally got the coils on the correct position. but have the tic-tic noise on cylinder 3. also noticed i have an exhaust leak on the same cylinder. took the spark plug and injected gas into cylinder and noise disappears for a few seconds!... what can be originating the tic noise?
valves, leak or carbs.... the carbs are the ones i would put apart because i have taken them apart twice, cleaned everything with compressed air and changed jets to 92.5
metalizzer
Hi to me again
solved it today. it was the exhaust leak!
a lot of helpfull people here!
vaosefodder!
