Keyless gas caps?
Keyless gas caps?
Has anyone had any experience with getting one to work on a FZR? i was thinking of getting one but i wanted to make sure it would work cuz our tanks are a 2 piece tank and tank cover.
- willandrip
- Level 7.0
Re: Keyless gas caps?
Cannot see it working myself.
They will fit the cover ok as the bolt pattern matches.
As you state the tank is a separate part.
The original cap latches and seals on the lip of the tank neck.
Keyless caps seal (via an o ring) filler cap to outer ring.
There would be a large gap that would require filling between the tank neck and the tank cover.
Even if successful, most covers are plastic and would flex quite a bit .
that was my thought, it'd have to have a spring seal set up like the oem gas cap to actually work and from what i'm seeing online none of them do that.
