Gasket Kit
Gasket Kit
Anyone know a good place to buy a full gasket kit? All I've found is this - http://www.partsnmore.com/parts/yamaha/ ... ng]=custom (Scroll until you see $155 Gasket Kit)
Not sure if anyone knows any better ones/places to buy.
Thanks,
AS
Thanks,
AS
Thanks,
ASnyder
ASnyder
- willandrip
- Level 7.0
Re: Gasket Kit
Wait... What ?
So you wish us to scroll through 14 plus pages to get advice....?
Be off with you.......or post what page it is on in the link at the very least.
Re: Gasket Kit
Sorry but, there's no actual "link" to the product all you do is put it in your cart and its there, but ill post a photo of it instead.
The photo just shows the package and the price beside it.
Sorry for the earlier inconvenience, when i go to the link before and scroll down its like right there.
Thanks,
ASnyder
ASnyder
- willandrip
- Level 7.0
Re: Gasket Kit
I know there is no direct link....I tried to put it up for you.
Anyways after your original post edit I found it straight off.
Soon as I saw "made in Italy" I thought Athena.
They are a good as you will get aftermarket gasket set for the 400.
You would be advised to use the OEM head and base gaskets though as it is Soooo much work if a pattern gasket fails in those two locations.
£100 is a good price for that kit in the UK so after your conversion rate (dollars/GB pounds) it seems a reasonable price in U.S./Canada.
- Level 3.5
Re: Gasket Kit
A ton quid is about right for a gasket set. When I used a pattern one in a cam cover it leaked, even though I used silicon to glue it in it wouldn't sit right it seems a couple of mm short. Then I used an OE and it was fine.
FZR400RR 3TJ Bimota SB6
Re: Gasket Kit
I bought the one I mentioned above, hasn't arrived yet but I will let you guys know how they hold up. Full price with shipping and tax came out to just under $200 (CAD)Evilchicken0 wrote:A ton quid is about right for a gasket set. When I used a pattern one in a cam cover it leaked, even though I used silicon to glue it in it wouldn't sit right it seems a couple of mm short. Then I used an OE and it was fine.
Thanks,
ASnyder
ASnyder
Re: Gasket Kit
Hi. I may be looking at doing a rebuild on an engine and was wondering what all gaskets come with this kit. I've searched, even on Athena's website, but can't find a list. Does it come with any carburetor gaskets or the rubber joints between the carburetor and intake?
Re: Gasket Kit
From off the top of my head no, I think you would need a carb rebuild kit(if you could somehow find it) but i may be wrong. Later today when I'm home I'll post pictures of all the gaskets laid out and you can see for yourself.Witchboard wrote:Hi. I may be looking at doing a rebuild on an engine and was wondering what all gaskets come with this kit. I've searched, even on Athena's website, but can't find a list. Does it come with any carburetor gaskets or the rubber joints between the carburetor and intake?
Sent from my Nexus 4 using Tapatalk
Thanks,
ASnyder
ASnyder
- willandrip
- Level 7.0
Re: Gasket Kit
There are no carb gaskets or rubbers in an engine gasket set .
The carb gaskets MAY be included in a carb rebuild kit .
It is an expensive way to buy carb gaskets though.
The rubbers are a separate part completely and would require sourcing from a dealer or manufacturer of pattern parts.
Re: Gasket Kit
Thanks for the replies guys. The carb rebuild kits I've seen don't come with them either, so I guess they are sold individually. Snydes, a pic of the kit laid out would be awesome. Thanks.
Re: Gasket Kit
Witchboard wrote:Thanks for the replies guys. The carb rebuild kits I've seen don't come with them either, so I guess they are sold individually. Snydes, a pic of the kit laid out would be awesome. Thanks.
Thanks,
ASnyder
ASnyder
Re: Gasket Kit
Missing from pics, head gasket, bottom gasket. There might be more missing I can't remember.snydes wrote:Witchboard wrote:Thanks for the replies guys. The carb rebuild kits I've seen don't come with them either, so I guess they are sold individually. Snydes, a pic of the kit laid out would be awesome. Thanks.
Thanks,
ASnyder
ASnyder
Re: Gasket Kit
Thanks. That's awesome of you.
Re: Gasket Kit
Just here to help out a fellow FZR lover. Also just to make sure, you know this is on my 400.Witchboard wrote:Thanks. That's awesome of you.
Thanks,
ASnyder
ASnyder
Re: Gasket Kit
I ordered one of these kits. Here's a picture of all the gaskets included.
