finch, thats the style that wont work.
that style mounts to where your stay/birdcage mounts and the other end mounts to this adaptor on the clip-ons.
Iv got the same thing but from an 04-06 r1. but at least i have the clip-on part covered.
was planning on making the stay mount plate -for the r1 front conversion I did- solid and drill and tapping it on the top to accomidate the stabilizer.
I have the one that mounts to the fzr.
look up some older ones.
Hi. I have a 1985 FZ750/1000 HYBRID I built around 1993...
Re: Hi. I have a 1985 FZ750/1000 HYBRID I built around 1993...
I think I need one FZspecific... Not FZR.
Shred.. if you do indeed have a bent up one for an FZ (steel frame) I would be a buyer if you're a seller! It must have the correct bracketry for both the fork as well as the frame though. Thanks again for straightening out my pic catastrophe.
Tom
Tom
- shredex
what is the diameter of your fork tubes?
I believe fzr has 32mm.
the stabilizer I have clamps onto the fork tube and the other end mounts to the frame side.
as long as the stabilizer is 24cm or longer(longer prefered) then you should be good.
Measured fork tube= 38mm.
Got carbs back together this morning... Gonna put 'em on and see if'n it runs.
IT RUNS!!! Holy crap it's as loud as I remembered it being...
It has a Krecker small baffle header that I cut and welded to fit the FZ Chassis. I also made s quiet slip-on from a 900RR muffler can but the bike was almost a half second slower with it if I remember correctly. but it was real quiet.
Idles@1000rpm and has instantaneous off idle throttle response. BOOM... RIGHT NOW.
Now to re-assemble the front fairing and get it down the road...
Maybe tomorrow a ride to see how bad the trans is.... Yee-haw....
Click herenickate wrote: PS. REALLY NEED TO FIND A STEERING STABILIZER/ DAMPNER.... Anybody got a sugg?
