Best place to tap in a voltmeter
I'd like to install a voltmeter on my fzr. where's the best place to tap in? I was going to use the extra headlight plug I have but it seems that does not show the same voltage as across the battery. Where would be the best place to put it?
Upgrades:
Re: Best place to tap in a voltmeter
I know where you can put it....zero9243 wrote:I'd like to install a voltmeter on my fzr. where's the best place to tap in? I was going to use the extra headlight plug I have but it seems that does not show the same voltage as across the battery. Where would be the best place to put it?
You could just put it across the battery if that's what yer lookin fer....
Put a switch on it so it doesn't drain the battery.
darrin
darrin
switch to the battery it is!
Upgrades:
thatkid wrote:I know where you can put it....zero9243 wrote:I'd like to install a voltmeter on my fzr. where's the best place to tap in? I was going to use the extra headlight plug I have but it seems that does not show the same voltage as across the battery. Where would be the best place to put it?
'92 FZR600
Lots of Powder
Lots of Powder
Hey back on this topic again. Can't I get a relay in order to put power to the voltmeter only when the bike turns on? What kind of relay would I be looking for to do something like that
Upgrades:
Pretty much any relay will do - you're talking a trivial power flow by automotive relay standards! Wire the coil in series with the key switch or kill switch; run a wire from the +ve pole of the battery to the common point of the relay switch, then to the voltmeter, then to the battery -ve.
You should be able to use an inexpensive MOSFET transistor even. You're looking at very small current levels.
darrin
darrin
