rear light R6
rear light R6
Has anyone moulded the diamond shaped led light from a 07 R6 into the rear end panel of a 90 fzr600?
If so, any pics as i am going to have a go. thanks
Re: rear light R6
hi,pwgun wrote:Has anyone moulded the diamond shaped led light from a 07 R6 into the rear end panel of a 90 fzr600?
Sorry no pics but I have seen it done both with the diamond shape tail light and the old style double barreled shotgun style GSXR taillamp
Re: rear light R6
just my
try one of these tails: http://airtech-streamlining.com/yamaz/OWO11991.htm
(and ya, the girl is sexy too)
There are no small days.
CrazySkullCrusher
Re: rear light R6
I'm in the process of switching to a clear alternatives lens with red LED 1157 bulbs inside, just waiting for all the pieces to get here. Looks like I will have to drill out some rivets to get the stock lens off, haven't really looked that close.
96 fzr600. R1 body kit.
94 xj600 seca 2: complete upgrade restoration.
73 Honda cb750 four: bored out 178 over (850 cc) street cam, smoothbore carbs, velocity stacks, corbin king-queen seat, 4-1 header with modified megaphone exhaust, dyna-s ignition, too many other mods to mention and still under construction.
72 Suzuki ts90 cci. First bike ever, bone stock and still starts with 2 kicks.
CrazySkullCrusher
Re: rear light R6
All done, the PO actually cut the old lens down and then pop riveted it to the tail light body. Clear alternatives lend snaps right in, the 1157 LED bulbs look good but not as bright as I had hoped. still, for $20 its a good upgrade and looks sharp.
Re: rear light R6
CrazySkullCrusher wrote:All done, the PO actually cut the old lens down and then pop riveted it to the tail light body. Clear alternatives lend snaps right in, the 1157 LED bulbs look good but not as bright as I had hoped. still, for $20 its a good upgrade and looks sharp.
W.F O
Nik H.
2. This is what I think...
Be aware of the difference!
Nik H.
Re: rear light R6
Csc, if you want custom led lights let me know I posted some pics of a few I've done. I can build any style you want.
sent from a portable leash
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
CrazySkullCrusher
Re: rear light R6
This it's what I ended up with, I think it looks good.
From the back:
From the side:
LED strip used to illuminate license plate mounted on underside of lens, spliced to tail light (blue& black)
Note the cluster LED bulbs visible through the lens.
Like I said, it's a super cheap mod and takes all of fifteen minutes.
From the back:
From the side:
Re: rear light R6
Not bad.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
CrazySkullCrusher
Re: rear light R6
Can't beat it for ~$20!
Re: rear light R6
CSC,CrazySkullCrusher wrote:Can't beat it for ~$20!
I admire your taste in indicators (have them on my "yellow peril" bike ) and for 20 dollars it is value for money mod,
the thing that worries me is your LED strip being in all the backblast from Tyre and exhaust which will corrode the very fine wiring of the strip where the tracks are exposed leading to premature failure.
If you want to use the strip mount it on model makers ply and put it inside the lens you can use a couple of computer board stand offs to keep the hot LED's off the plastic
OR you could do this :-
http://www.saltmine.org.uk/kgb/yp4.html
Just thinking out loud
CrazySkullCrusher
Re: rear light R6
Thanks for the concern, but it's designed to be mounted under the rocker panels of cars. the LEDs are sealed in a soft plastic tube, melted shut at both ends. Also they were 2 for $5 on Ebay, so I really don't care if one dies on me.
