led lights
floridafzr600
led lights
Post by floridafzr600 »
do 94 yzf led turn signals for the front. are they just plug and go
blensen
Level 2.5
Level 2.5
Re: led lights
Post by blensen »
Sure. Just make sure you're using the correct wires. One will give significantly brighter than the other. I can't remember which is which offhand.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: led lights
Blue is running light, Black is ground; Green or Brown ("Chocolate") is the signal for that side.
blensen
Level 2.5
Level 2.5
Re: led lights
Post by blensen »
What would we do without you, Don?
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
floridafzr600
Re: led lights
thanks everyone but don what do i do if the led lights are only a two wire
Re: led lights
Ignore the blue (running light) wire. Hook up the hot bike wire to the hot LED light wire, and ground to ground.
blensen - You'd get by, just not as well ... :rofl:
floridafzr600
Re: led lights
DonTZ125 wrote:Ignore the blue (running light) wire. Hook up the hot bike wire to the hot LED light wire, and ground to ground.
thanks i didnt know if it would be that easy or if i had to do resistors and what not :tks:
Re: led lights
Depends on the arrangement. Some LEDs have built-in ballast resistors; some need to be added to slow the blink rate. The other option is to splice in a flasher relay meant for LEDs, but you'll lose the self-cancelling function of the OEM system.
floridafzr600
Re: led lights
ok fzr 600 has 3 wire the lights have two is there a way i can still make it with running lights too or am i just stuck with turn signals only
CortezLoetz
Re: led lights
Post by CortezLoetz »
The other option is to splice in a flasher relay meant for LEDs.
_____________________________
fluorescent led bulbs
led ceiling lights
led strip lighting
