Trouble Firing
Dean0493
Trouble Firing
Post by Dean0493 »
Hi everyone,
I Have a 1995 FZR600R Foxeye (4JH), and i recently did the fork seals on it, the front was lifted for the day so i could get the forks off. Anyway, i rebuilt everything and all was good, i then went to start the bike and all i got was it turning over, it wasnt struggling turning over it just wouldnt fire. I thought i might have unplugged something or forgot about something but i went back through and checked everything and it all seems in its place, the kill switch works, clutch switch and kickstand switch so its not any of them, has plenty of fuel and the fuel pump is priming, have all dash lights, indications and headlights etc
I checked the battery and it had 12V + so it cant be the battery, checked the plugs today and wasn't getting any spark from them, the plugs seem fine and wern't oily or anything, checked the coils and they were getting power to them so i thought it cant be them. Its just strange how before i did the seals it has never failed to start, not once, and now that everything is back together it doesn't want to start, i will put some new plugs in it tomorrow and hope that sorts it out. Other than plugs and leads i have ran out of things to eliminate but i have probably missed plenty of things. I have read about people having Stator problems? etc
Is there anyway i can check the stator? What should it be at?
Any help is greatly appreciated, and hopefully i can be part of a quality community :-D
Thanks,
Dean.
vmaxmike
Re: Trouble Firing
Post by vmaxmike »
You should check the pick-up coil. (behind left engine cover with stator) Unplug it at the wire harness and check for continuity with an ohms tester, positive to red/white wire and neg to other wire. Resistance should be between 80-120 ohms. If not, that might be the problem although not sure why it would die just sitting for a short period.
I just had to replace this on my '93 due to a no spark situation. Got if from a parts bike I bought.
reelrazor
Wrench
Wrench
Re: Trouble Firing
Post by reelrazor »
YOU are most likely missing something very simple.....un-re-plugged connector block....terminal pushed back out of connector block, ground wire loose, etc.
Go back and re-check everything you came near when you did the fork leg removal, AND everything else wiring related.
Assume NOTHING!! Physically check everything
