Hi Guys ,
been new to FZRs ,what should be the standard size sprockets front and rear be on my 89-90 3HE noticed that the rear is a 46 tooth and what do you suggest for a chain x ring o ring , did RK
I have got a few tight spots on the chain and even if i slack off on the adjusters it still there, so i might as well relace the whole lot although saying that the sprockets look fine , do you think i would get a way with just a new chain?
cheers
Al
chain and sprocket sizes fzr 600
If all else fails (hit it with a big hammer)
Re: chain and sprocket sizes fzr 600
Stock size for the 3he is 15/45 with a 530 chain. If you're going to replace the chain you might as well do the sprockets too (better wear characteristics). Some might say you don't have to but I'm not one of those people. An RK ro DID O Ring chain with good sprockets will do the trick.
thanks for that sweekster,
just taken the sprocket cover off and wow what a mess so much gunge and dirt, but on a plus the clutch is smoother now after removing all the crap and re greasing the clutch realese mechanism ,
it has a 15t front and 46 rear am i ok on these
Cheers
Al
Cheers
Al
Mines 15 front 46 rear, maybe it's a Brit thing? look here for diff sizes e.t.c. 520 Conversion viewtopic.php?f=8&t=216
+5K on changing out the chain & sprockets as a set anyway else is just a waste over time.sweekster wrote:Stock size for the 3he is 15/45 with a 530 chain. If you're going to replace the chain you might as well do the sprockets too (better wear characteristics). Some might say you don't have to but I'm not one of those people. An RK ro DID O Ring chain with good sprockets will do the trick.
So if i stick with the 15t front 46t rear but go down the 520 route im good to go
how many links though , I have seen these on ebay, is this the same for the 89-90 3he
http://cgi.ebay.co.uk/YAMAHA-FZR600-92- ... 4147e66fce
thanks
Al
thanks
Al
Stock length is 106 links if I remember correct. 15/46 in a 520 should be fine and that will probably fit the stock length chain.
