shifting problem
trump19
shifting problem
Post by trump19 »
hey guys well now that my bike is running i have discovered that its hard to shift and its really hard to find neutral any ideas IDK
rocket till the wheels fall off
Re: shifting problem
trump19 wrote:hey guys well now that my bike is running i have discovered that its hard to shift and its really hard to find neutral any ideas IDK
As an Ex Yamaha service engineer I can tell you one thing for certain yamaha neutrals a bitch to find I have abatch of RD400's and they have ALL got a FALSE neutral between 2 & 3rd gear.The FZR I have when the bike is running & I look for neutral I MUST rock the bike PERIOD to get neutral.
_Will_
Level 5.5
Level 5.5
Post by _Will_ »
I must just be lucky, I routinely beat on mine and am always able to find nuetral without a problem and rarely get a false neutral. Good luck, Geo knows his stuff so he's probably right. Mine only has trouble when first started and the oil is cold as far as shifting goes, have you tried after riding around a bit to get the oil thinned out some? Maybe try some sea foam and see if it's gunked up from sitting?
rehaume
100+ Posts
100+ Posts
Post by rehaume »
i've got no problem finding neutral either, half up from first... always their never fails.... hell sometime i miss second and hit neutral
Wichita, KS
95' FZR600
88' FZR400 with YZF 600 Motor
yahoo msg: swingline1021
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
stiffer clutch springs may help
trump19
Post by trump19 »
yea i think ill try the sea foam see if that helps. the problem when its running i cant find neutral when its off i can so i dont know whats up with that... but i do have to say a big thanks to all that have helped me so far another question i have my buddy has a 91 and he's telling me his is slipping in 2nd any ideas on that it only does it in 2nd .
Fizzinatorr
Level 6.5
Level 6.5
yeah it's the 2nd gear slip that happens to some FZR's
_Will_
Level 5.5
Level 5.5
Post by _Will_ »
trump19 wrote:yea i think ill try the sea foam see if that helps. the problem when its running i cant find neutral when its off i can so i dont know whats up with that... but i do have to say a big thanks to all that have helped me so far another question i have my buddy has a 91 and he's telling me his is slipping in 2nd any ideas on that it only does it in 2nd .
there's a write up in the wiki on the sea foam usage I think, I don't run it normally in my oil since when I ran it right before a change the stuff came out so dang thin but as a one time treatment to get the gunk out like I mentioned I would guess it does a good job. I only say guess due to having not taken my motor apart after or before using it, just seeing the oil I treated with it.
JRK5892
Level 1.5
Level 1.5
Post by JRK5892 »
have you thought simple and tried to adjust the linkage and then lock it back in with the jam nuts?
http://www.thepowderpro.com
The Powder Pro
trump19
Post by trump19 »
ill give that a shoot
