just like the title says
i was thinkin about pickin up a extra set of carbs,,and rebuilding them over the winter,
and then swapping them out onto my 1989 FZR
i just wanted to double check to see if all the carbs are the same on all years,,or were there any slight changes?
my bikes a 1989,,so i know they already have a hand full of differences on it
just didnt wanna waste money buying the wrong year stuff,
thanks
all 1989-1999 carbs the same?
Re: all 1989-1999 carbs the same?
The only differences I know of is the EXUP (Cali) model. I would get photos of the one you want before you buy. We can verify it for you.
Here is a pic of the EXUP carbs - see the hoses that come out the bottom the carbs on the right? They attach to the vapor canister. I removed them and filled the holes with JB Weld. There are some differences in the jet sizes as well.
ok,,i was just wanting to pick up a nice set on ebay,,and go from there,,id still love to keep my bike runnin in case of a good day of weather here and there
ill find some pics,,of some auctions im watchin
what do the 2 hoses do that go to nothing do,,i guess all the carbs have them?
i just wondered
thanks
i just wondered
thanks
They are overflow hoses.mjw7800 wrote:ok,,i was just wanting to pick up a nice set on ebay,,and go from there,,id still love to keep my bike runnin in case of a good day of weather here and there
i just wondered
thanks
Ive got a set of parts carbs in my parts bin and they are different that whats on my bike. I am assuming they are from a 90, since my bike was a 90, but had the engine and carbs swapped out, but the parts came with the bike. The spot where the cables atach to the throttle were slightly different, and a few other minor differences, but the jetting was the same, just different hardware.
- fzrbrandon
- Level 7.5
This is a VERY good point and I was going to bring it up a earlier tonight but got sidetracked. I think there was a change over around '92 or so. I bought a set of carbs for my '92 because I needed to replace the throttle bell crank. I bought a set from a fellow board member who, if my memory serves correctly, said they were ALSO from a '92 but the bell crank was in fact different (as Freeze mentioned). The difference is that one of the two cables (don't remember which) is actually screw-tightened on on one set but on the other the cable just slips into a cable receiver (for lack of a better word) and is not tightened in any way. If you check the fiches for the cable part numbers you'll see that there is a different push or pull cable at some point. I'd look it up and post links but I'm too damn tired so I'm going to bed! LOL!mrfreeze5 wrote:...The spot where the cables atach to the throttle were slightly different, ...
http://www.fzrbrandon.com
ok,,ill look at mine,,i already have a 90 and up swing on on my 89,,so maybe i have some diff carbs?
i dont wanna waste money on anything buying the wrong stuff,lol
thanks
thanks
