Yeah, when the engine's hot the coolant is under much higher pressure than the oil so you'll probably see coolant in the oil first. If your oil starts to look milky that's the coolant...modkingfzr600 wrote:p.s ....because of gravity, you may very well notice coolant in the oil first before you notice oil in the coolant
