NOW ITS SLIPPING
payne3400
NOW ITS SLIPPING
Post by payne3400 »
aside from the rattle i have when the bike is running, the clutch is now slipping when its cold and the biting point is now right at the end of travel of the clutch lever. I have adjusted the clutch at the engine end and readjusted the free play at the lever but its still the same.
Any ideas? :headscratch:
WNY ROGO
Level 2.5
Level 2.5
Re: NOW ITS SLIPPING
Post by WNY ROGO »
Let it warm up.
...ROGO...
1993 Yamaha Fzr 600-RIP
Stock
1990 Yamaha Fzr 600-Current
Mods
Flush mount Front Signals
R6 Headers Modded By That-Kid
YZF600R Front End Swap
YZF600R Swingarm Swap
92 Fzr Single Upper
8000k HID Headlight Kit
95 YZF600R Gauge Cluster
YZF600R Gas Tank
Rear Tire Hugger
Fzr Forum===WnyRogo93Fzr
payne3400
Post by payne3400 »
WNY ROGO wrote:Let it warm up.
good one, but surely the biting point should be around half way instead of at the end??
The slightest touch on the lever causes it to slip even when warm
95FZR600
Post by 95FZR600 »
Oil? What kind did you use? What about adjusting clutch.
WNY ROGO
Level 2.5
Level 2.5
Post by WNY ROGO »
He said hes adjusted both points. The only thing I could think of is maybe the clutch is going. Did you look at it and see if it is beat or wore or broken?
...ROGO...
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
95FZR600
Post by 95FZR600 »
Well then, time for a new bike then.
95FZR600 wrote:Well then, time for a new bike then.
:rofl:
Payne - it may be time to pull the clutch pack, inspect the disks, springs, basket and hub.
sweekster
Post by sweekster »
I agree in that it's time to inspect the clutch. If you have to replace the clutch it's neither hard nor expensive to do it yourself.
payne3400
Post by payne3400 »
I looked at the plates when it was in bits and they were within the spec listed in the manual, and steel plates didn't look warn either.
I have been told that if the clutch plates have been replaced before with some cheap ones, that could cause it, but i never remember it being this bad before it was stripped.
The oil i'm using is what is listed by yamaha, don't know what oil was in it before.
I've ordered a clutch cable just incase it is stretched and causing these problems, but if that don't work then i guess i'll have to strip the clutch down and recheck the plates, basket etc.
Thanks for all the help
Did you check the basket and hub for notches? While de-clutched, the plates vibrate and pound grooves into the basket fingers and hub splines; the plates can hang up in these grooves and can't be properly squeezed together by the pressure plate.
