wierd oil leak maybe?
- deathcomesarippin
I have noticed on the right plastic underneath the driver seat looking from the back of the bike some kind of liquid that looks like it is being sprayed on, I checked the brake fluid and oil levels and both are good, im guessing maybe its a little bit of oil being sprayed out at a time but I odnt know where from. ill get some pictures soon to make this easier
modded air box,
K&N drop in,
race tech fork springs,
R6 header-kerker exhuast,
things to come, 520 conversion, jet kit, yzf front brake calibers
K&N drop in,
- shredex
Re: wierd oil leak maybe?
finally another one from florida!!!
anyways...Im guessing its a oil leak also...check where all the seals are that contain oil. (both right side engine covers, head gaskets)
could also be coolant coming from a hole in the hose...
one way to test your radiator hose is to turn your bike on and rev it to a high rpm and if theres a hole then coolant will be sprayed out of it...
- deathcomesarippin
ok will do first thing tomorrow I replaced the valve cover gasket about a month ago but ill still check it out to, thanks
modded air box,
K&N drop in,
K&N drop in,
- shredex
yes, but it will still leak if not tightened up enoughdeathcomesarippin wrote:ok will do first thing tomorrow I replaced the valve cover gasket about a month ago but ill still check it out to, thanks
what part of FL you live in???
Fork seal
- deathcomesarippin
nah its not a fork seal I looked at it today and it was the head gasket so I took it off and put more sealant on it i hope this should work, but I live in plant city close to tampa
modded air box,
K&N drop in,
K&N drop in,
- shredex
just make sure you tighten them enough.deathcomesarippin wrote:nah its not a fork seal I looked at it today and it was the head gasket so I took it off and put more sealant on it i hope this should work, but I live in plant city close to tampa
they have a spacer that will allow you to tighten it without overtightening it...
tampa is close to me
