fork tube size
mike94fzr600
Level 4.5
Level 4.5
fork tube size
Post by mike94fzr600 »
i am looking to some Dual Headlight and it ask me for Fork Tube Size . it the chart they have right are they 38 mm if not what size are they? i have a 1994 600
my rides
2000 chevy z71 4x4
1994 fzr 600
the_finch
Level 8.5
Level 8.5
Re: fork tube size
Post by the_finch »
From your avatar pic it looks like you have the stock fork tubes, which makes them 38mm. I suppose you're looking for a streetfighter headlight assembly for your bike? Any clamps you get to go on your bike have to be 38mm.
Hope that helps. my2cents
1997 FZR600RJ
mike94fzr600
Level 4.5
Level 4.5
Re: fork tube size
thanks finch yes they are stock. i am looking for streetfighter headlight. they ask for the size of the forks for the clamps to mount them i just want to be sure they are right size befor i order them
my rides
2000 chevy z71 4x4
1994 fzr 600
the_finch
Level 8.5
Level 8.5
Re: fork tube size
Post by the_finch »
Then the 38mm clamps should treat you well. If you are "streetfightering-out" your bike, one thing you may consider before ordering the headlight is what to do about the terribly soft front suspension. It would sorta suck to get an awesome headlight on your bike, and then a few months from now decide to to a fork swap for newer/better forks (which you could always rebuild them with springs/cartridge emulators) and have to buy the clamps all over again.
All that to say, be sure to plan ahead. my2cents
1997 FZR600RJ
megaloxana
Re: fork tube size
Post by megaloxana »
Contact abs600fzrr and buy his 636 front fork setup. It would MAKE your street fighter Cruisin
sweekster
Re: fork tube size
Post by sweekster »
Agreed
Yeah no need to worry about whether it will work on an FZR because it curretly IS on an FZR. as Borat says "It's NIIIIIICE"
mike94fzr600
Level 4.5
Level 4.5
Re: fork tube size
well i might just have to look him up and see whats up
my rides
2000 chevy z71 4x4
1994 fzr 600
