Is this the stock rear brake?
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
I'm looking at doing brake pads and I was wondering if this is the stock caliper. The PO replaced the front with R6 brakes but didn't say anything about the rear.
YAM93
Re: Is this the stock rear brake?
Post by YAM93 »
looks stock to me.
order some MOOSE rubber brake-bleed caps from Dennis Kirk and get rid of that duct tape
:banana: :thumbsup:
Deputy1042
Post by Deputy1042 »
Definitely stock.
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
Are sintered brake pads ok to use? Denniskirk.com has an omminous sounding warning on the product page.
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
YAM93 wrote:looks stock to me.
:banana: :thumbsup:
I can't find those caps on denniskirk. you don't happen to know where I should be looking?
Deputy1042
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
The duct tape is a nice touch. Looks like you're also missing the spring clamps...
darrin
Luke-a-Tron
Post by Luke-a-Tron »
Sintered pads are both fine and recommended.
YAM93
Post by YAM93 »
http://www.powersportspro.com/pages/par ... amaha.aspx <--- put in your bike year and model and look under "REAR BRAKE CALIPER" listing, it has a drawing, part numbers and prices.
Wow you guys have sharp eyes, I didn't even notice that, I guess I was busy looking at the duct tape, well, you have to admit, at least he was covering them with something.
Anyway, that link above....... ragedigital is talking about part # 7. Also if you don't have it part # 11 is the black cover.
Also, if you have time / money ..... consider upgrading to braided steel brake lines. Spiegler is very good but expensive. I think either Galfer or Russell also makes compatible brake lines. The stock rubber ones get crummy and rotted after a while, plus the brake fluid in them can go bad easier.
At the minimum bleed the brakes and put new (MOTUL RF600) DOT 4 brake fluid in there. Make sure it's DOT 4.
Woops, I almost thought you were a new member. You already know all this stuff. (Friday nite insomnia again)
:deal: :headbang: Rock on Tommy!
Oh, i used the EBC HH pads from Dennis Kirk, they're really nice and strong. No problems.
Deputy1042
I'm hoping he took the photo after he took the cover and spring clamps off to check the brake pads...I wouldn't think he'd be riding around like that :whistle
