Bleeding the brakes
tclayton9
Level 2.5
Level 2.5
Bleeding the brakes
Post by tclayton9 »
Can someone give me the easy way on bleeding the brakes. I just cleaned my front calipers, and decieded to use my fzr parts first and see what happens before I buy r6 parts.
pefrey
Level 5.5
Level 5.5
Re: Bleeding the brakes
Post by pefrey »
tclayton9
Level 2.5
Level 2.5
Post by tclayton9 »
Is that the only way to do it. I was trying to find aanother way to do it.
Harrysf707
100+ Posts
100+ Posts
Post by Harrysf707 »
You could try a mityvac, though it's a bit more expensive. Pefrey's way works perfectly well, it's even cheaper.
~JM~
100+ Posts
100+ Posts
Post by ~JM~ »
I picked up a vacuum tool from Harbor Freight & it works well for a cheep tool.
I used it on a completely dry hydraulic clutch set-up on a Yamaha FJ1200 & it worked great. Just make sure you keep an eye on the master cylinder reservoir so it doesn't go empty on you.
The Ketchup squeeze bottle looks like a good way to go also.
~JM~
Genesis
Level 8.0
Level 8.0
Re: Re: Bleeding the brakes
Post by Genesis »
~JM~ wrote:I picked up a vacuum tool from Harbor Freight & it works well for a cheep tool
~JM~
I have the same one, works good.
My FZR6 Rebuild
