Racing Stands
white86tercel
Racing Stands
Post by white86tercel »
http://www.fzronline.com/forum/viewtopic.php?f=2&t=7938 mentions that some stands won't work because of the left fork's pointed shape. Unfortunately they don't show any pictures of stands that will work.
I found the attached stands for sale for $100. Do you think they will work with a 1990 FZR600.
Re: Racing Stands
Post by thatkid »
No, those will not work. The FZR doesn't have spool mounts so the stand on the left is out. The right stand is a Lockhart Phillips stand and while it can be used with the front end of an FZR, great care must be used in order to do it. Not something you have time for if using the bike for racing.
white86tercel
Re: Racing Stands
Thank you for the quick reply.
I am mainly looking to use the stands for winter storage (keep weight off tires) and basic maintenance. Do you think using the left stand for the rear wheel and the right stand for the front wheel will meet my needs?
Re: Racing Stands
Post by thatkid »
The left stand won't work period with the fzr. The right stand would work for storage but I wouldn't trust it for basic maintenance. You'd be better off with a front stand that lifts from the triple and not the fork legs. For the rear you need a stand with pads/platforms that will go under the swingarm.
Honesty, just spend the money on good stands. It's well spent and worth it in the long run for piece of mind.
white86tercel
Re: Racing Stands
Are there any models of stands that you recommend?
GreyImport
Re: Racing Stands
Post by GreyImport »
This is the kind u need for the rear............
http://www.ebay.com/itm/CHROME-REAR-SWI ... ceRpt=true
Cant see the point in spending hundreds on the top of the line stuff if its just for maintenance and/or storage.
1990 FZR250R 3LN1
http://2fiftycc.com/index.php
LiteTek Carburettor Seal Kits
Redoliander
100+ Posts
100+ Posts
Racing Stands
Post by Redoliander »
I have a pit-bull rear stand that works for spool or non spool swingarm.
For the front I have a vortex stand that goes under the triple tree.
http://m.motorcycle-superstore.com/Item ... yleId=9122
Re: Racing Stands
take alook at this and you will see what you can do for yourself:-
http://www.saltmine.org.uk/fzr/paddockstand.html
adding spools to swing arm:-
http://www.saltmine.org.uk/kgb/yp7.html
also on this page are pictures of the "correct" FZR front stand as well as some DIY tools for for etc
http://www.saltmine.org.uk/fzr/fork.html
sweekster
Re: Racing Stands
Post by sweekster »
