I'm not 100% certain on the 400s, but I would imagine they are similar.ashtong63 wrote:I have a '90 400. I had plastic, then clip, then 2 washers, then threaded plastic cap. Not sure this is RIGHT, but it's what mine had.j
If you add more washers under the clip where the plastic washer goes, you begin to "richen" up the circuit. Someone may have tried to lean yours out a tad.
A threaded cap - do you have Mikuni carbs or Keihn?
