I need a favor. I think my frame is bent.
I need the distance from the top front of the neck to the large main cross brace above the swing arm bolt. (appx. 1.25 diameter tube).
Should be around 27 13/16 (27.8125) inches or 706.4375 mm.
Went to test fit the tank cover and does not fit with the upper fairing bracket on. Top of frame appears to be short above the engine.
Installed engine cradle and they are low and forward of the rear bolt holes.
