Carb removal
Redoliander
- 100+ Posts
Carb removal
How in the heck do I remove the carb bank? I loosened the screws underneath the carbs that hold the boot on. Also took the bracket off the back side. I've used a hair dryer to warm the boots but still can't get them off. Please give me some pointers.
Redoliander
- 100+ Posts
Carb removal
Never mind. I got it. Needed a little wd40 and some more persistence. Those buggers are on there good!
Re: Carb removal
If the boot clamps are loose the carbs are probably just stuck to the rubber (haven't been removed in a long time)...
Rocking them (side to side and back and forth) will loosen them up and they'll pop out.
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Re: Carb removal
Oh good! Ha ha
-Pete
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
Current Toys
1995 FZR600
2002 Ducati 900ss
2008 Versys 650
1991 CB250
1978 CB350
Past Bikes
1981 CM400t
1981 GS650
1998 FZR600
1994 VS800
2004 SV650
- kilika2
- 1000+ Posts
Re: Carb removal
I suspect that you will have to do the hair dryer trick again when you decide to put them back on. I've had to do it multiple times.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Redoliander
- 100+ Posts
Carb removal
Yea I figure putting them on ill have to use the hair dryer or just roll it out in the Arizona sun for a bit. The bike had been in storage for about 8 years and my buddy I got it from said it only got about 14 mpg due to the jet kit. It started right up but figure ill pull the carbs and clean them.
