Ng,ng86 wrote:So basically what the wiki is saying, is that I should find some velocity stacks to connect my carbs to my k & n's? Can it really be that simple?
Yes it is that simple, when Y-G was here last summer, we used PVC plumbing pipe slid inside the original air box connecting rubbers. The idea being the rubber at the lower end clamps to the carb as normal BUT the PVC pipe sticks up beyond the rubber at the top so the pod clamps to that.Y_G took about an hour & a half to cut the PVC to length and fit the pods and Synch the carbs when assembled.
He is a bit ticked off as he had done this regularly back in the late 70's and '80's (there is a picture of his RD "Blue Streak" on his site that shows it back in the '80's fitted with stacks) and had completely forgotten the trick and then remembered it late in the day when he read here that guys with pods were struggling to get the tuning right.
Other people have used another air related gadget to tune as well called a FLOW commander<?>
Your call .............
