Fzr600 Frame All fearing tabs and excess tabs removed..
Custom spacer machined to accept a stock fzr600 steering shaft and bearings but use the top and bottom triple trees from an 03 R6
Complete 03 R6 front end
Steel braided Brake lines
stock Honda CBR600 master cylinder
Aftermarket Clip ons
Relocated the key under the seat
Acerbis street fighter headlight with high and low beam
Full trail tech vapor gauges with temp sensor. mount welded to the upper clamp
full rear end off of 02 R6
Relocated the shock mount
Vortex lowering links
520 chain conversion
When i first got it all cleaned up
After the transformation!
