someone do a quick voltage check for me?
yttaf
Re: someone do a quick voltage check for me?
Post by yttaf »
this is a replacement tci I just bought from a well know member on here because mine was fried
thatkid
Post by thatkid »
yttaf wrote:I checked the plug end of the tci unplugged & has 12v to both orange & grey wire. I plug the tci back in & turn it over while checking the orange & no movement & still .34v & went up to .44 while turning over. Then I tested the grey wire had 10.32v & went dows to 8.3v while cranking
10.32v batttery needs charging?
have you checked the pick up coil resistance, to eliminate the coils check their primary and secondary windings if you haven't already, apart from that im stumped.
yttaf
Post by yttaf »
battery is fully charged as I keep my battery tender on it. Plus if I get 12v without the tci hooked up it shouldn't be less when it is hooked up?
I haven't checked my pickup coil but I know it's nasty. There is the metal stripe on it, well it's all gunked up & shit. I tried cleaning it up but it didn't help, so I guess I need to test that, but I'm probably gonna guess that it's bad...
As for testing my coils my ohm meter doesn't go to kilohms so I can't test them correctly. The setting would be 1K ohms right?
thatkid
Post by thatkid »
yttaf wrote:hmmm wonder why I have 12v at 1 but not the other??? My replacement digital ignitor bad?
few hours ago you had 12v on grey @ TCI, that's why i mentioned the battery
read page #1 the coil ohm values are there.
yttaf
Post by yttaf »
yeah if I disconnect the tci I still have 12v at the grey wire. I plug it back in then it drops to 10.34v
