Gurgle, deadish spot
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
My bike accelerates fine under throttle (1/4, 1/2, 3/4, etc) through the rpm range but when I am cruising between 5-6k on the freeway (keeping a constant speed) the bike will sort of gurgle slightly. I won't lose speed or anything, but to GAIN speed i need to twist the throttle quite a bit.
Upgrades:
manveru
Level 3.5
Level 3.5
Re: Gurgle, deadish spot
Post by manveru »
check minor things first. whens the last time you replaced the plugs? cleaned carbs etc.
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
Yah i'm going to try to replace the plugs later today and see if that does anything. Carbs were cleaned spring of last season and I run a little seafoam every oil change (supposed to keep the carbs from getting gummed up i think, or at least put off the need for cleaning them).
Upgrades:
haunter
Post by haunter »
do you have stock or jett'd carbs?
that range is usually controlled by needle clip position
to check if its cause by a lean or rich condition, give the bike some choke and try it again,if its worse, you are rich, if it gets better, you are lean
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
haunter wrote:do you have stock or jett'd carbs?
Cool, i'll give that a try. I also just went in halfsies on a carb tuner tool with another member on the site so maybe that would help too?
Upgrades:
