My YZF750R
Re: My YZF750R
Na, he didn't buy mine. But there will be a few pics of them together. From 20ft, his will look a lot better than mine because of my miss matched fairings. But I have an OHLINS.
I'm not planning on doing anything with mine for a while. I'm starting to think about fairings and where to get them from. Place in the UK is the only one left that makes road version of the stock body work anymore. I can get the front, sides, and belly pan for about $400-500 shipped. I've heard that they are a little slow, but very good quality and fitment. Although I may decide to go after a new front end first. I have to see how the summer work schedule goes. I'd love to get an Ohlins front end for it.
Re: My YZF750R
Cad, yup they are slow as they are fresh made for you not off some dusty shelfcad600 wrote: I've heard that they are a little slow,
Re: My YZF750R
Who are you using? Skidmarx seems to be good over there n they have a us distiburator over here in the states(getting my double bubble through them) I can't wait to see the pictures YZF 750 <33333
1992 FZR 1000
Re: My YZF750R
id like to come over and check it out sometime now that i know your so close! and go check out that bad ass fzr of yours
Re: My YZF750R
My contact is Chris which is all I can bloody remember (getting old but can remember Portsmouth or Southampton based company ) I was given his contacts thro Alan at ALKAMOTOMcFizzer wrote:Who are you using? Skidmarx seems to be good over there n they have a us distiburator over here in the states(getting my double bubble through them) I can't wait to see the pictures YZF 750 <33333
He has Ebay shop as well as website of the same name.
Re: My YZF750R
OK, I've been wanting to do one particular thing since I got this bike, So I got a package in the mail today that I've been waiting on for a while now. Here are the pics.
Now I have a full Ohlins set up for the bike. I was going to just do the drop in cartridge, but the shop wasn't too thrilled with the condition of my original forks. So I decided to go all the way instead. This set up is for an 07/08 R1. I had them do the "race" prep on it to lengthen the forks 10mm so they are only 25mm (1 inch) shorter than the stock ones. Which when I set them level with the triple, I will only be about 1/2" shorter than the setting I was originally running. My original forks are fine, and the shop is a little anal about suspension. But I don't mind one bit. I love these things. Got a major chubby as soon as I opened the box.
I've already got the front fender, axle, and calipers. I'm intent on using my R6 front wheel because it uses 310mm rotors just like the new R1 does. And it will fit into the stock triples. I only have to get a 1mm thick bushing made to take up the difference in overall diameters. The YZF750 uses a 56mm dia fork bottom while the R1 uses a 54mm. Once I get that sorted out, I'll be on the road with full Ohlins suspension.
I'm going to put my original forks back onto the bike until I get it ready to go. 4 weeks without riding is killing me right now.
Re: My YZF750R
So now I needed to take everything else apart to work on the front end.
I originally wanted to have some 1mm thick bushings made to take up the difference between the 54mm forks and the 56mm triple. But I was having a hard time with this in my head. After talking to a few people about the item, I started re-thinking how it should be done. Then I finally realized what size the material really is. Billy had tried to explain it to me before I started down the road of machine work for the bushings and I decided to give it a try. So I found some .04" aluminum sheet from a local place for $2.65 and a $0.43 PVC pipe fitting to give me some basic shape. Cut out a section and bent it around the pipe. Trim to fit and bend it over to create a lip. All done. I still might try the machine route, but I need to rethink the size of the material given the pain in the ass it was to get the fork tubes in there. Going below 1mm wall thickness on something 56mm DIA may not work.
Re: My YZF750R
Tubes are in.
R6 rim from my 600 build works as it uses 310mm rotors just like the R1 does.
6 Pot Radial mount calipers. Only bad part about them is the cost of replacing the pads. Going to be over $100 for new brake pads.
Love the look of the caps.
Re: My YZF750R
Not....
...fair
...fair
Re: My YZF750R
Ah, come one now. You can do the same thing. All you got to do is be willing to sleep in the dog house for a few weeks till the wife gets over the purchase. LOL
chefen2006
- Level 3.5
Re: My YZF750R
OHH.............AGHH..mm.......IIGHPM...
I
WANT
THIS
TOO
I
WANT
THIS
TOO
Re: My YZF750R
Those Ohlins are amazing
soooo tempting..... but I have to be a nagger and say "why not racetech?" it would be just as good, but not as gold.....
There are no small days.
Re: My YZF750R
Simply because they are Ohlins. I don't view the Racetech as being on the same level as these. Don't get me wrong though as the Racetech stuff is good.Nick Howe wrote:Those Ohlins are amazingsoooo tempting..... but I have to be a nagger and say "why not racetech?" it would be just as good, but not as gold.....
Re: My YZF750R
I feel you man, its like I tell my rice rocket friends, no matter how fast they are, the badges are still "toyota, honda, nissan," and not Lambourghini, Ferrari, or even BMW
You can dress up a dog like a lion, but its still a dog
-no disrespect to the ricers, mad props to your fab skillz, I had a 240sx that was held together with zip ties
Re: My YZF750R
Well, it has been a while with the YZF750. I had to sell off the Ohlins front end. I'm still not over that. But some times ya got to do what ya got to do.
I got tired of the miss-matched body work and my plan was to paint it the entire time. So I finally got around to doing it. I thought I had developed a coolant leak or a blown head gasket so I dug into the bike a little but it turned out to be a small weep from a coolant line. That gave me ample time to paint. I used aircraft stripper to get the factory paint off the tank. There was bondo one one spot from the factory as the tank had not been repainted before I got it.
Anyways, here is a reminder of how it looked when I picked it up.
And here it is now.
Since I had to sell off the Ohlins, I wasn't going to go back to the original YZF calipers. They suck. So I did the R6 brake upgrade which also required some Duc rotors so I didn't have to shave down the pads.
Later.
And here it is now.
Later.
