17 inch rear wheel swap in a fzr400-600?
Just what the subject says. I'm looking for the answer to what 17 inch rear wheels will fit in a fzr400 swing arm and what mods need to be done to get the chain to run strait and true from the counter shaft sprocket on the fzr600 motor. If a 520 chain and sprocket kit makes the clearance easier to achieve than that info will help in the build.
thanks for your help in direction,
Re: 17 inch rear wheel swap in a fzr400-600?
not sure if you would get a 17 into the swingarm sensibly as they will be wider than the 18 in there. these are some that have been suggested to fit with mods, but i don't know what mods they would be! A 4.5" TZ (or TZR) 250 rear wheel, An 88-89 GSXR-750 rear wheel, An F2 rear wheel.
i do know that for the 3en1 you can use a 3tj swingarm and need the pivot bushed down with a couple of top hat washers, think its from 20 to 16mm or something. you may need to remove some material from the sprocket carrier to get it lined up. mine had about 3mm shaved off to get everything straight.
Fzr400 3tj x2
'94 cbr 900rr
'94 cbr 900rr
hi,fastbiker1973 wrote:Just what the subject says. I'm looking for the answer to what 17 inch rear wheels will fit in a fzr400 swing arm and what mods need to be done to get the chain to run strait and true from the counter shaft sprocket on the fzr600 motor. If a 520 chain and sprocket kit makes the clearance easier to achieve than that info will help in the build.
look in the wiki I wrote this up about 2 years ago. together with all the various combinations I used and the GOTCHA's i found and solved.
- loganlexow
Less machine work and looks stock is the yzf600 swingarm/wheel. That's the route I went and the parts are silly cheap. Handles like a DREAM.
Full specs are yzf600 swingarm/wheel, gsxr750 shock w/stock links, 2003 cbr600rr forks/wheel. This thing is AWESOME
Sent from my HTC Desire Z using Tapatalk
1990 FZR400 with a Kerker exhaust for now. In the process of fork swap, shock swap, and 17" rear wheel
If you can find one, i think an SZR660 wheel just might be an easier fit
Chris
Chris
3x RG80 Gamma
3x RG80 Gamma
1993-1995 GSXR 750. Needs a different hub-(GS500 I think) I'm working on one right now. Neil
Sorry, I should have made it clear-this is for the 400 Deltabox arm. Neil
Neil RZR wrote:Sorry, I should have made it clear-this is for the 400 Deltabox arm. Neil
George, waiting on bearings. Hopefully by weekend. I'll try and post pics. Neil
- Camala_Pillion
Neil,Neil RZR wrote:George, waiting on bearings. Hopefully by weekend. I'll try and post pics. Neil
George's point was that not everyone is familiar with the "deltabox" arm and a picture considering the confusion so far would have cleared up the point and some useful advice obtained.
If anyone can help with picture posting I'd be glad to snap a couple. My computer skills are the minimum! Neil
If someone can help me with picture loading, I'd be glad to share. Thanks-Neil
Here are Neil's photos.
hi there.i know that the topic is 17 inch rear wheel swap but i d like to ask if anybody knows if an fzr 100 2la rear wheel 4.5 x 18 would fit the stock 600 swing arm
i mean with no mods
