I need a picture like this, But of a 400
FZR400 Forum
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I need a picture like this:
But for a 400, could anyone help me?
My FZR6 Rebuild
95FZR600
Re: I need a picture like this, But of a 400
Post by 95FZR600 »
BMiller should be able to help you out with that request
ashtong63
Post by ashtong63 »
I can get you one in the next day or two, but not right now...
Are you looking for something specific? I've got a pretty good memory of what mine looks like under there if you've got a question about where something goes.
FasterThanUr
100+ Posts
100+ Posts
Post by FasterThanUr »
I happen to have mine off.It's far from stock tho.It did look more like your pic once apon a time.The thing thats mostly different is the location of the coils
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
Genesis
Level 8.0
Level 8.0
Post by Genesis »
FasterThanUr wrote:I happen to have mine off.It's far from stock tho.It did look more like your pic once apon a time.The thing thats mostly different is the location of the coils
I want to get rid of the radiator filler neck so I can use the fzr400 air box I have to fit under the yzf600 tank, but I f read your sig right I need a 05 r6 radiator to do that, thanks for the pic
My FZR6 Rebuild
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I got a r6 radiator on its way :headbang: One more bracket I can cut off.
My FZR6 Rebuild
FasterThanUr
100+ Posts
100+ Posts
Yeah I have the 05 rad.I just used two long bolts"See Red Arrows in pic"And bolted that to the top of the rad.
And I did just have the bottom bailing wired to the header,but when I did the r6 headders I put in a bracket
It works great.I was able to use both fans without them rubbing,but it was vary close :thumbsup:
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
shredex
Post by shredex »
Genesis wrote:I need a picture like this:
whats that thing coming out of the frame where the rust is with the holes??
this does not exist on my bike
ashtong63
Post by ashtong63 »
shredex wrote:whats that thing coming out of the frame where the rust is with the holes??
I was curious about that too, my 400 doesn't have it either.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
That is because I have a 600 it holds the front of the air box
My FZR6 Rebuild
ashtong63
Post by ashtong63 »
Don't know if you still need it but here's what my '90 400 looks like.
I have since run the wiring harness up through the frame spar so I could put on the airbox. Boy did that suck...
Ashton wrote:I was curious about that too, my 400 doesn't have it either.
Obviously I'm an idiot, I do have that but it's bolted on and is a different color.
Genesis
Level 8.0
Level 8.0
Post by Genesis »
Thanks, I am trying to figure why the 400 air box sits further forward than the 600 air box. that 400 engine must sit further back in the frame.
My FZR6 Rebuild
Genesis
Level 8.0
Level 8.0
Post by Genesis »
Did you just plumb you FZR inlet to the lower right corner outlet? and vice-versa? the FZR outlet to the upper left r6 inlet?
My FZR6 Rebuild
mxryder21
Level 1.5
Level 1.5
Post by mxryder21 »
FasterThanUr wrote:Yeah I have the 05 rad.I just used two long bolts"See Red Arrows in pic"And bolted that to the top of the rad.
dude, is it possible to mount the r6 rad how you have it on a 600 frame? NICE JOB :thumbsup:
Genesis
Level 8.0
Level 8.0
Post by Genesis »
mxryder21 wrote:dude, is it possible to mount the r6 rad how you have it on a 600 frame? NICE JOB :thumbsup:
I am working on a bracket with modking right now I will keep you posted.
My FZR6 Rebuild
