17 inch rear wheel swap in a fzr400-600?
FZR400 Forum
fastbiker1973
Post by fastbiker1973 »
Just what the subject says. I'm looking for the answer to what 17 inch rear wheels will fit in a fzr400 swing arm and what mods need to be done to get the chain to run strait and true from the counter shaft sprocket on the fzr600 motor. If a 520 chain and sprocket kit makes the clearance easier to achieve than that info will help in the build.
thanks for your help in direction,
taggy
Level 1.5
Level 1.5
Re: 17 inch rear wheel swap in a fzr400-600?
Post by taggy »
not sure if you would get a 17 into the swingarm sensibly as they will be wider than the 18 in there. these are some that have been suggested to fit with mods, but i don't know what mods they would be! A 4.5" TZ (or TZR) 250 rear wheel, An 88-89 GSXR-750 rear wheel, An F2 rear wheel.
i do know that for the 3en1 you can use a 3tj swingarm and need the pivot bushed down with a couple of top hat washers, think its from 20 to 16mm or something. you may need to remove some material from the sprocket carrier to get it lined up. mine had about 3mm shaved off to get everything straight.
Fzr400 3tj x2
'94 cbr 900rr
fastbiker1973 wrote:Just what the subject says. I'm looking for the answer to what 17 inch rear wheels will fit in a fzr400 swing arm and what mods need to be done to get the chain to run strait and true from the counter shaft sprocket on the fzr600 motor. If a 520 chain and sprocket kit makes the clearance easier to achieve than that info will help in the build.
hi,
look in the wiki I wrote this up about 2 years ago. together with all the various combinations I used and the GOTCHA's i found and solved.
loganlexow
Post by loganlexow »
Less machine work and looks stock is the yzf600 swingarm/wheel. That's the route I went and the parts are silly cheap. Handles like a DREAM.
Full specs are yzf600 swingarm/wheel, gsxr750 shock w/stock links, 2003 cbr600rr forks/wheel. This thing is AWESOME
Sent from my HTC Desire Z using Tapatalk
1990 FZR400 with a Kerker exhaust for now. In the process of fork swap, shock swap, and 17" rear wheel
SouthendChris
Level 2.0
Level 2.0
Post by SouthendChris »
If you can find one, i think an SZR660 wheel just might be an easier fit :thumbsup:
Chris
1990 3LN3 FZR250 - back in safe hands :)
3x RG80 Gamma :)
Neil RZR
Post by Neil RZR »
1993-1995 GSXR 750. Needs a different hub-(GS500 I think) I'm working on one right now. Neil
Neil RZR
Post by Neil RZR »
Sorry, I should have made it clear-this is for the 400 Deltabox arm. Neil
Neil RZR wrote:Sorry, I should have made it clear-this is for the 400 Deltabox arm. Neil
:nopic
Neil RZR
Post by Neil RZR »
George, waiting on bearings. Hopefully by weekend. I'll try and post pics. Neil
Camala_Pillion
Post by Camala_Pillion »
Neil RZR wrote:George, waiting on bearings. Hopefully by weekend. I'll try and post pics. Neil
Neil,
George's point was that not everyone is familiar with the "deltabox" arm and a picture considering the confusion so far would have cleared up the point and some useful advice obtained.
Neil RZR
Post by Neil RZR »
If anyone can help with picture posting I'd be glad to snap a couple. My computer skills are the minimum! Neil
Neil RZR
Post by Neil RZR »
If someone can help me with picture loading, I'd be glad to share. Thanks-Neil
RxRC
Post by RxRC »
Here are Neil's photos.
neogeo
Post by neogeo »
hi there.i know that the topic is 17 inch rear wheel swap but i d like to ask if anybody knows if an fzr 100 2la rear wheel 4.5 x 18 would fit the stock 600 swing arm
:tks:
neogeo
Post by neogeo »
i mean with no mods :duh:
