Last Winters build. (From archives) (56k Beware)
For the bad boyz, here a little arena for you to get fightin'!
Re: Last Winters build. (From archives) (56k Beware)
Post by thatkid »
ShogunTX wrote:Holy Cow you have a lot of wrench time in that bike! Nice idea on the hydrolic tank support.....Do the Tuddles Know you left??
Haha. They got nothing! I say bolt on schmolt on.
Yeah the time is estimated well over a 1000 hours of labor. It just wouldn't end!
Genesis
Level 8.0
Level 8.0
Post by Genesis »
I was watching this all last winter, then didn't got on the net for like 8 months, turned out awsome man. say with your next build if your interested in a r6 swing arm, I might have one for sale.
My FZR6 Rebuild
95FZR600
Post by 95FZR600 »
What is this?
Post by thatkid »
That is the piece that connects the header to the very bottom of the frame. Bolts on with the part that connects the dogbones and the shock and the frame together.
95FZR600
Post by 95FZR600 »
The reason I ask is because I had that left over after my swing arm swap.
YAM93
Post by YAM93 »
those pictures just don't do justice to all your suffering and effort, although you did an awesome job of photo-documenting almost every step of the process.
...hopefully when you put all the guts into the 400 frame you won't need to re-invent the entire bike again.
:banana:
you did it the right way for sure, step-by-step, day by day. most of us do not have even a fraction of the constitution you or MrFreeze5 have to do these complex builds.
:udaman
Post by thatkid »
YAM93 wrote:those pictures just don't do justice to all your suffering and effort, although you did an awesome job of photo-documenting almost every step of the process.
:banana:
:udaman
:whistle :whistle That's about all I can say for re-inventing the entire bike again. Since the only things that are moving to the 400 frame are the motor and front end it leaves a lot of things to toy with. Subframe, swinger, rear wheel, tail, going to get that damn headlight design right this winter too. The tank may come over but I'm not sure yet. I don't know if I could function if I didn't constantly have something that needed to be reworked.
Always appreciate the Kudos though. I do wish I could have kept the posted comments but it was an ordeal to just get the pictures over. That damn broken tap still haunts my dreams!
Post by thatkid »
Genesis wrote:I was watching this all last winter, then didn't got on the net for like 8 months, turned out awsome man. say with your next build if your interested in a r6 swing arm, I might have one for sale.
Thanks man. Thanks for the offer on the swinger too. I already have that part all picked out inside my head. I just have to talk to some folk and make sure it's going to work. I will say this if it works.... Ain't no one done this before!
megaloxana
Post by megaloxana »
95FZR600 wrote:The reason I ask is because I had that left over after my swing arm swap.
:rofl:
nate..i'll allow the selling of the bike since you're swaping over to a 400 frame. :banana: Can't wait to see what you conjure up with over the winter.
95FZR600
Post by 95FZR600 »
That was an awesome build. I like the colors you used and it all just flowed nicely. Mad machine skills to.
sweekster
Post by sweekster »
All is can say when it comes to this is..Keep it sexy Nate..Keep it sexy. But you already know how i feel about your bike and the work you put into it. :thumbsup:
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
:rofl:
And now that he has your approval, the build will go on!
:mrgreen: :mrgreen: :mrgreen:
Upgrades:
kikepiz
Post by kikepiz »
:udaman
Good work!
Post by thatkid »
kikepiz wrote::udaman
Good work!
Thanks! This winters build has begun but there isn't enough to showcase yet so I've refrained from starting a build thread just yet.
shredex
Post by shredex »
Good work!
can you give us any spoilers for what your doing?
what bike?
400 or 600 frame??
anything!!!!?
cant wait to see what your going to do after seeing your last build
:cheers:
Return to “Streetfighter'd / Naked / Chopped”
