WINNER VIDEO POSTED :: RAFFLE!!! ContourHD 1080p helmet cam
This area is owned and operated by ThatKid (Nate)
Post by thatkid »
Alright folks, it's Christmas time. So I figured I'd share the wealth a little. I'm offering up a new ContourHD 1080p helmet cam. The retail on this bad boy is $280 and it is currently the #1 helmet cam on the market. This helmet cam will shoot 1080p video at 30fps or 720 video at 60fps. Super small form factor and all self contained. You can get multiple mounts for it and a full waterproof case good to 10 meters. The specs are below for this particular cam.
Specifications
Manufacturer Contour
Optics
Angle of View 135° in 960p and 720p
110° in 1080p and WVGA
Video
HD Resolution Settings: 1080p: 1920x1080 pixels, 30 fps
960p: 1280x960 pixels, 30 fps
720p: 1280x720 pixels, 30 or 60 fps
SD Resolution Settings: 848x480 pixels, 60 fps
Sensor Type: 5 Megapixel Sensor
Video Format: H.264 compression, saved as MOV (.mov) file
Audio
Microphone: Built-in
Compression: AAC Audio Compression
Storage Memory: MicroSD card, up to 32GB capacity
Average Recording Times: 1080p: 15min/GB
960p: 15min/GB
720p: 30min/GB (30 fps), 15min/GB (60 fps)
848x480 WVGA: 60min/GB
Connectors
PC Connection: USB 2.0 (data connection and battery charging)
Power and Battery
Battery Type: Rechargeable Lithium-Ion
Battery Life: Up to 3 hours
Charging: Via USB to computer or included USB Power Adapters
Charge Time: Approximately 4 hours
Additional Information
Body: Water Resistant
Aluminum and Fiberglass
Compatible with TRail Mount System
PC Compatibility: Windows XP, Vista, Windows 7; Mac OS X 10.4 and later
Software: ContourHD Easy Edit™ software
Dimensions (H x W x D): 2.1" x 1.3" x 3.75" (53mm 34mm x 95mm)
Weight: 4.3oz / 123 grams
Operating Temperature: 5°F to 104°F / -15°C to 40°C
Warranty: Contour (formerly Twenty20 VholdR) warranties the ContourHD 1080p for 180 days from the date of purchase of product, unless otherwise indicated by your local government’s warranty laws. The warranty applies only to defects in material and workmanship and not situations caused by impacts or abuse. For complete warranty information, please refer to the Product Information Guide.
The ticket price is $10 and I'm limiting the tickets to 25. You can buy multiple tickets if you'd like. Raffle will close on Dec 24 and winner will be chosen on Christmas. I need at least 20 tickets for the raffle to happen. Money will be due before the close of the raffle. paypal or mailing of a check is fine.
I'm hoping I can have one of the Site Admins or Directors draw the name assuming there will be one that isn't buying a ticket. :whistle :cheers:
I'll update names as people say they want in. Let me know how many tickets.
1 Scott
2 Target30 x 2
3 Mrfreeze5 x4
4 Zero2943
5 Blensen x2
6 Haunter
7 Reelrazor x2
8 Geo x3
9 Kilika2
10 Sweekster x2
11
12
13
14
15
16
17
18
19
20
21
22
Target30
Level 7.5
Level 7.5
Re: RAFFLE!!! ContourHD 1080p helmet cam
Post by Target30 »
im in for 2, pm me your paypal
I did that.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Totally sweet deal!
thatkid wrote:I'm hoping I can have one of the Site Admins or Directors draw the name assuming there will be one that isn't buying a ticket.
Just to be fair, I would be willing to record a video of having all names in a bucket and then have one of my kids pull the winner* out. That way you could see it happen and know there was no bias.
*However; if the winner is not present at the time of name drawing, I get the camera.... ha! Kidding of course.
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
Im in for 2. Lemme check and see if I still have your paypal info...
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
Sign me up for 1
Upgrades:
blensen
Level 2.5
Level 2.5
Post by blensen »
Put me down for 1 as well. PM me your paypal.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Post by thatkid »
ragedigital wrote: Just to be fair, I would be willing to record a video of having all names in a bucket and then have one of my kids pull the winner* out. That way you could see it happen and know there was no bias.
That would be sweet. Then we could just post the video and everyone gets the excitement watching till the end!
haunter
Post by haunter »
sure why not......PM me your pp again
Post by thatkid »
OK, the list has been updated. Also, so everyone is aware, this isn't a raffle to make me lots of cash. Just thought this might be a fun way to offer up a sweet helmet cam. I still had to buy it and while I get a deal, it's still pricey.
New addition - if we make it to 25 tickets, the forum is getting a $25 donation.
Whoot!
Post by thatkid »
And a bump for good luck so this will hopefully happen. Still need 12 more tickets sold.
reelrazor
Wrench
Wrench
Post by reelrazor »
thatkid wrote:And a bump for good luck so this will hopefully happen. Still need 12 more tickets sold.
PM me a paypal, I am in for two of those.
Post by thatkid »
OK, I didn't want to mention this till I was sure and had the camera in hand. It is the retail box so it does come with the flat surface mount and a goggle mount. I can order up other mounts or the waterproof case for the winner. That will be on the winner to pay for though.
Come on people! Tickets are available.
Post by thatkid »
10 days left. Still need 10 tickets. It's a sign! Come on folks, this is less than you'd spend on a lunch and the outcome could be much better.
mrfreeze5
Level 8.0
Level 8.0
Post by mrfreeze5 »
thatkid wrote:10 days left. Still need 10 tickets. It's a sign! Come on folks, this is less than you'd spend on a lunch and the outcome could be much better.
Come payday, I may buy a few more if it will help support the forum :whistle
kilika2
Post by kilika2 »
I'm still going to go in on this. Just like mr freeze I need to wait for payday. However I just found out that we are starting to carry these at Best Buy. Just to let everyone know we have them for 299.99 sooooo 299.99 or 10 bucks... your choice.
Chris.
1995 FZR600 Sold :-(
2006 R1 Sold :-\
2009 Buell 1125R :-)
Return to “Green Machine Customs [Custom Fabrication / Machining / Powdercoating]”
