bend the little metal bit toward where the needle would be to lower the fuel level in the carbs ? yes ?
I have bent this and the level has not changed ,
bend towards carb (needle)to lower level , bend toward float bowl (away from needle)to raise .. correct ?
Float levels , am I missing something ?
ssimonn
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimonn
Re: Float levels , am I missing something ?
oh and can i put a 2kr fuel pump on the 3ln ?
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
SS,ssimonn wrote:bend the little metal bit toward where the needle would be to lower the fuel level in the carbs ? yes ?
you should be setting the Float height as per the tool that Rage Digital came up with, saves a lot of messing about
viewtopic.php?f=7&t=4997&p=52890&hilit= ... ool#p52890
ssimonn
the height for the 250 would be .. ? 13mm as well ?
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimon,
I did the setup to measure fuel level with little plastic tubes on each carb and it was just impossible for me. That is when I decided to just set the float height. Much easier to see and measure and it works great. I had to reset the float height a couple of times to get it where I wanted it but it is worth doing.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
ssimonn
truth , all I was going to do was get one with messing around with the tube ,measure that one , make a device like is shown above to do the rest . I have used that technique on my other bike but I had the height it should be set at to make the card. This time I dont
yet
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimonn
after I do it with the card , if i put the tube on and look the fuel level will have changed ? or no ? I'm thinking yes ..
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
ssimonn
ok I set the floats at 13mm , I'll see how that goes.
FZR250R 3ln3 1991
NSR250R mc18 1989
NSR250R mc18 1989
