Switching Headlights - Single to Dual
Ok, so I wanted to get rid of the single headlight and go to the dual. How should I get another plug in there for the second headlight? Simply splice into the same wires for the single light or wouild that make both headlights weak? Any ideas?
I will not tiptoe through life to arrive safely at death.
Re: Switching Headlights - Single to Dual
Toby,toby42 wrote:Ok, so I wanted to get rid of the single headlight and go to the dual. How should I get another plug in there for the second headlight? Simply splice into the same wires for the single light or wouild that make both headlights weak? Any ideas?
I just did this about a month ago. what I did was make up a "pigtail" which consisted of 6 wire (2 pairs of 3 wires) that plug into the harnesses original headlamp socket And the other end has 2 pairs of 3 female connectors that plug on to your new bulb set up.
be sure to get them in the right order .This arrangement allows you to revert at any time to single light should you wish to sell the bike as near stock as possible.
- Location: currently north carolina/ hometown fair lawn new jersey
hey if u need the duel headlight assembly i got one waiting to be shipped out i also can throw in one of the connectors that plug into the headlight.
1999 fzr 600 *vance and hines can and header*stage 2 jet kit*r1 front seat*frame painted gloss black*"ducati" style mirrors with integrared smoked blinkers*r1 tail and pit-eck fiberglass undertail molded into a 1 piece tail and undertail*black powdercoated brake and clutch levers*Bridgestone BT-014*single headlight 92 front fairing swap*powdercoated black engine covers(TK)*aluminum coolent tank(modking)*2007 cbr1000rr rear seat*zero gravity smoked windscreen cut short*lowered front 2"
- shredex
why would you want to go from the single to DUAL!!!
some of you guys are crazy!
ya i know i went the opposite way
, but whatever to each is own. and in the lighting aspect duel headlights is defenitly alot better to see with.
If you're interested, I would straight trade my duals for your single, wires are included.
'92 FZR600
Lots of Powder
Lots of Powder
Del - I already traded... sorry! I just need the extra plug which,
Lafaro - Yeah, man, that'd be great! PM me your paypal addy and I'll send you some $$ over for it and shipping.
ShredEx - I'm going w/ the streetfighter look... but on the cheap, so I didn't buy new headlights, just swapped for the dual headlights that have a SF 'look.' That single woulda looked pretty danged goofy by itself! ;o)
