R6/R1 Digital Gauge Swap
Re: R6/R1 Digital Gauge Swap
reelrazor wrote:
yamaha_george wrote:
shredex wrote:I would suggest before completly drilling threw the case, magnitize the tip of your drill bit so it catches any lose metal.
Shredex,
I think you will find that the engine case is alloy so drill chips are non- magnetic :-}
the Tinkerer's Life is NEVER that simple canofworms
If you were really worried about it you could always get a slugger bit :
http://www.jancy.com/index.cfm?fuseacti ... ductid=112
These capture the drilled slug and minimise the amount of swarf by cutting the only the perimeter.
If you buy a Vor-tech blower system for your car, they supply one of these to drill and tap your oil pan (while it is in place) for the blower bearing return oil line.
RR,
Good Lord man we will drag these guys into the 21st Centuary & make them engineers by force. ClapHands
Sheesh I thought it was only me that had a bad tool collecting habit Nerd
shredex
Post by shredex »
I really would like to get my speedo to work, but im still really afraid of drilling the hole.
I also dont know how to program the speedo healer.
and my battery still drains while it sits (off) I think my relay is bad or something. or the guy that had the bike before didnt wire one to the digital gauge.
Shreddex,
That dying battery problem has to be solved before you find yourself stuck someplace.then you can do a proper follow up on the clock set up.
Be brave we are all here to help out :-}
95FZR600
Post by 95FZR600 »
Raise that swing arm up and drill the damn hole!
shredex
Post by shredex »
95FZR600 wrote:Raise that swing arm up and drill the damn hole!
what bit did you use?? I have the bits that reelrazor was talking about, but the shanks on them are to big and will not fit my drill at all. mine will fit 3/8" shank and the slug bit has like a 5/8.
95FZR600
Post by 95FZR600 »
I dont remember. I just grabbed one out of the tool box that was close to the sensor diameter and drilled. Then I used JB weld and clear silicone to it.
shredex
Post by shredex »
95FZR600 wrote:I dont remember. I just grabbed one out of the tool box that was close to the sensor diameter and drilled. Then I used JB weld and clear silicone to it.
Iv got some epoxy putty and clear rtv silicone. will the epoxy putty work? it should.
ill do the drilling when I swap out my old swinger for the newer one.
mszilves
Level 1.5
Level 1.5
Post by mszilves »
Shredex, you'll want a 3/4" drill bit.
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
95FZR600
Post by 95FZR600 »
Thats the one mark! I double checked out there and 3/4 it is.
shredex
Post by shredex »
I know what bit size I need, its just I dont have a bit that size with a shank that will fit my drill. I was asking how the hell you drilled it without removing your whole engine and putting it on a milling machine because there the only ones with the right size shank.
95FZR600
Post by 95FZR600 »
I used a rigid cordless drill. Its like 1/2 inch shank. You cant use your dad's craftmans drill. J/k.....
shredex
Post by shredex »
95FZR600 wrote:I used a rigid cordless drill. Its like 1/2 inch shank. You cant use your dad's craftmans drill. J/k.....
I have a Bosch cordless with a 1/2" shank....
The only thing craftsman I own is a router...
:banana: lol
shredex wrote:I know what bit size I need, its just I dont have a bit that size with a shank that will fit my drill. I was asking how the hell you drilled it without removing your whole engine and putting it on a milling machine because there the only ones with the right size shank.
NOPE,
use fleabay to look up "blacksmith drills" these come with the big taper shank turned down to round to fit a drilling machine with a chuck.
http://cgi.ebay.co.uk/14-0MM-BLACKSMITH ... m153.l1262
If you have a mickey mouse hand drill the chuck may be too small but most modern ones are 10mm max and the blacksmith drills I have will fit (just).
with the core borer drill RR showed I made up a holder that could be chucked up as well but that is OTT for most folks.
shredex
Post by shredex »
iv got one with a 1/2" shank...to bad my drill will only except 3/8"...
Im still not going to be doing mine until I do the swinger swap
crichtonracing
Post by crichtonracing »
I'm trying to get my R6 speedo to work but I'm not having any luck. I've heard that the 00-01 R1 tach will work, is that true?
/\/\att
1990 Yamaha FZR600 Fighter
2003 Yamaha YZF-R1 Dragbike
Return to “Electrical: MODs/How-To/Issues”
