How to: cheap ignition advance
reelrazor
Wrench
Wrench
Re: How to: cheap ignition advance
Post by reelrazor »
yamaha_george wrote:RR,
nice write up and for once as you say cheap & relativly easy. My only point is the make & model of your timing light.
I have not seen one like that except from SUN when I had my workshop (still have it but at 4K miles and 10 flying hours in each direction ...........)
Pointers to sources would be good too as I doubt that many "ordinary" folk have one
Thanks for the work. Are you going to add it to the WIKI ??????
S &F
Y-G
That one is Ferret Instruments unit. http://www.ferretinstruments.com/Catego ... ights.html
they are a local company/employer----being Fox Valley Instruments back in the day..Now GxTAutomotive/Ferret. Their factory/shop is four blocks from my house. They used to have a 'blemished sale' each spring...would sell equipment with scratches in the housings and other cosmetic damage at auction pricing. Don't know if they still do that or not. A Brother in my square is a draftsman for them..I'll ask.
The area Advance Auto has a wall display of timing lights....from $39 on up...about $80 will get you digital. I am sure this is true at the other do-it-yourselfer auto parts stores.
http://www.advanceautoparts.com/
Northern tool: http://www.northerntool.com/webapp/wcs/ ... ng%20light
Autozone: http://www.autozone.com/autozone/catalo ... ming+Light
And, there are 28 different units up on Ebay right now.."timing light, digital' including a very nice Mac Tools unit at $41 right now.
If someone would PM me with instructions to add to wiki I would be glad to.
(and almost any hod rod car guy is gonna have one in his garage-If I had to borrow one it would be a matter of which friend was at home,not which one HAS one....I dunno..that's the kinds of friends I have)
reelrazor
Wrench
Wrench
Post by reelrazor »
Just a quick update...
I don't know why I waited so long to re-do this on my bike(or how I was tolerating it when I went from advanced to stock!~).
It is SOO much punchier...any whack of the throttle is soo much more productive.
shredex
Post by shredex »
i wanna do it! but does it wear engine life?????
i use 87 octane from hess/7-eleven
i want to be able to do this (note* skip to about 0:45 he only is accelerating and the wheel comes up! and its a 600)
reelrazor
Wrench
Wrench
Post by reelrazor »
shredex wrote:i wanna do it! but does it wear engine life?????
No. It will not accelerate engine wear.
THIS HOW TO IS ON THE WIKI
shredex
Post by shredex »
ok, I completed this mod today!
hella lot of work
*drilled out the screws holding the pickup to to the cover and basicaly f*ck up the mounting part on the cover. thought I was a GONER!
I was VERY lucky to find that there are also mounting holes for the coil on the Engine case itself!!!
so I drilled and tapped those holes and of course, the tap BREAKS off in the one hole! Thought i was a goner then!
It took forever to get the holes elongated on the coil..i used grinding stone and everything...then i just took my drill bit and pushed it into the side of it till it drilled out what i needed.
then i used a washer to space out the pickup to line up with the timing things on the flywheel because the engine mount one is set back a bit.
luckely the tap broke off over the surface and had enough to hold the other side of the coil up.
i used nice new bolt on other hole and it holds great...a bit trickier to mount the cover though when using the engine mounts for the coil...
Then I prepared to hit the start button.
I press it...starter turns twice and vroom! it starts! yayayayayayayaay
took her for a spin and it did make the front end lighter! not a whole lot but there is a difference there!
ill have to check what timing its at. I dont own a light so I gotta go to the shop.
anyways...I need a new stator cover...pre-unscrewed lol my way is holding though!
thanks for the write-up reel!
question.
How far is to far with advancing?
you did a 6 degree, but would 10 degree be to much and screw it up? or would it make it better?
You will know if it is too far advanced the bike will go in reverse :j/k
Bratman3401
Post by Bratman3401 »
Is there anyway to do this without the timing tool? what would happen if i just drill the holes out a little longer and try it? will i break something?
reelrazor
Wrench
Wrench
Post by reelrazor »
Bratman3401 wrote:Is there anyway to do this without the timing tool? what would happen if i just drill the holes out a little longer and try it? will i break something?
No. I just wanted to be positive that I was getting at least 5° of advance. And, I like to KNOW where it's at for any future tweaking.
You will basically be limited by the allen screw head coming into contact with the pickup body itself, so it is not like you can advance waaay too much.
Keep an ear out for pinging....and if you get any, either back off the advance a little, or go up a grade on fuel and you will be fine.
Do it tomorrow.
Bratman3401
I am about to go out and do it right now actually!
Bratman3401
I just finished this mod and I cant feel a low end difference but high end i definatley feel it it jumps at about 8 grand on.
Bratman3401
Okay nvm i was wrong! It has power thru out the rev range i just didnt let it warm up at take the full advantage of the power. But once it warmed up omg it makes a huge difference it hauls butt! Thanks for the great idea im looking forward to more free mods so keep me posted!
reelrazor
Wrench
Wrench
Post by reelrazor »
Bratman3401 wrote:Okay nvm i was wrong! It has power thru out the rev range i just didnt let it warm up at take the full advantage of the power. But once it warmed up omg it makes a huge difference it hauls butt! Thanks for the great idea im looking forward to more free mods so keep me posted!
yeah, well it aint free...but $52 gets you adjustable cam sprockets from Falicon...next time you check/adjust valve lash....put them in.
Degree the cams and add in 10° of retard to the intake cam(higher dynamic compression) and really make it punchy!!!
haro504
Level 7.5
Level 7.5
Post by haro504 »
i asume this is the same for the yzf engine i might have to do this one between parts packages
RR,
These :PT no. 384-402 YAMAHA FZR600/ 400 SPROCKET SET $54.00
@ http://www.faliconcranks.com/sprocket_price.html
Return to “Electrical: MODs/How-To/Issues”
