tank swap question
gussy
tank swap question
Post by gussy »
Does anyone know if the 97 yzf 750 tank is the same as the 600r thundercat tank and would the r6 99-02 gas cap fit this tank ?
I found one for cheep.
Re: tank swap question
The '95-96 YZF600RG/RH use the same tank as the YZF750. The '97+ YZF600 uses a somewhat different tank, with an external fuel pump. I can't comment as to the mounts and outlines, etc.
As for the cap, a quick check of EvilBay shows a selection of aftermarket keyless caps that claim to fit all years of R6, and the early YZF600 (= YZF750 tank). Check it for yourself, but I'd say it looks promising.
cad600
Post by cad600 »
I can confirm that the mounts between the Foxeye (600 & 750) are the same as the Thundercat (600).
But I would recommend against using it. Only reason is that the internal fuel pump is a PIA. It is difficult to source one that is in good working order if it ever goes out. There is no petcock switch so it takes a little bit for the gas to stop flowing if you ever have to take the tank off. It also uses the vacum lead from cylinder 1 into the petcock which is just another line to connect and disconnect when servicing is done. Beyond that, I like that tank a lot more than the Thundercat tank. The internal fuel pump has an advantage in that it removes the external pump from the mass of crap under the tank.
gussy
Post by gussy »
Thanks guys
